Heart disease detection - Solution#
In this tutorial, we will focus on applying federated learning techniques to a classification problem using Scikit-Learn, a popular machine learning library in Python. We will walk you through the process step by step, from setting up the federated learning environment to evaluating the model’s performance.
Scikit-Learn, also known as sklearn, is a popular machine learning library in Python. It provides a wide range of tools and algorithms for tasks such as data preprocessing, feature selection, model training, and evaluation. Sklearn is widely used for tasks such as classification, regression, clustering, and dimensionality reduction. It offers a user-friendly interface and integrates well with other libraries in the Python ecosystem, making it a go-to choice for many machine learning practitioners and researchers.
%load_ext autoreload
%autoreload 2
Table of content#
The dataset
Task 1: training plan
Task 2: the experment
Task 3: model validation
Tutorial#
The dataset #
The Heart Disease dataset available at https://archive.ics.uci.edu/dataset/45/heart+disease is a widely used dataset in the field of cardiovascular research and machine learning. It contains a collection of medical attributes from patients suspected of having heart disease, along with their corresponding diagnosis (presence or absence of heart disease). The dataset includes information such as age, sex, blood pressure, cholesterol levels, and various other clinical measurements.
It was collected in 4 hospitals in the USA, Switzerland and Hungary. This dataset contains tabular information about 740 patients distributed among these four clients.
A federated version of this dataset has been proposed in Flamby. Following thier actions, we preprocess the dataset by removing missing values and encoding non-binary categorical variables as dummy variables. We finally obtain the following centers:
Number |
Client |
Dataset size |
0 |
Cleveland’s Hospital |
303 |
1 |
Hungarian Hospital |
261 |
2 |
Switzerland Hospital |
46 |
3 |
Long Beach Hospital |
130 |
For teaching purposes, we decided to merge: client0 with client3 and client1 with client2. The final federated scenario, in this way, is the following:
client1, with 349 elements
client2, with 391 elements
Task 1: Defining the training plan #
A training plan is a class that defines the four main components of federated model training: the data, the model, he loss and the optimizer. It is responsible for providing custom methods allowing every node to perform the training.
In the case of scikit-learn, Fed-BioMed already does a lot of the heavy lifting for you by providing the FedPerceptron, FedSGDClassifier and FedSGDRegressor classes as training plans. These classes already take care of the model, optimizer, loss function and related dependencies for you, so you only need to define how the data will be loaded.
In this tutorial we are going to use an SGDClassifier, so the related FedSGDClassifier training plan.
Model arguments#
model_args is a dictionary with the arguments related to the model, that will be passed to the Perceptron constructor.
IMPORTANT For classification tasks, you are required to specify the following two fields:
n_features: the number of features in each input sample (in our case, the number of pixels in the images)
n_classes: the number of classes in the target data
Other model arguments depend on the specific model you are using, and are defined in the model definition. Refer to the model documentation
Training arguments#
training_args is a dictionary containing the arguments for the training routine (e.g. batch size, learning rate, epochs, etc.). This will be passed to the routine on the node side.
IMPORTANT To set the training arguments we may either pass them to the Experiment constructor, or set them on an instance with the setter method:
'exp.set_training_arguments(training_args=training_args)'
The setters are available also for single training arguments, like:
'exp.set_aggregator(aggregator=FedAverage)'
TO_DO:
Apply the scaler to your data
Define training args: num_updates, batch_size.
Define model args.
from fedbiomed.common.training_plans import FedSGDRegressor, FedPerceptron, FedSGDClassifier
from fedbiomed.common.data import DataManager
from sklearn.preprocessing import MinMaxScaler
class SkLearnClassifierTrainingPlan(FedSGDClassifier):
def init_dependencies(self):
"""Define additional dependencies.
return ["from torchvision import datasets, transforms",
"from torch.utils.data import DataLoader"]
def training_data(self, batch_size):
In this case, we rely on torchvision functions for preprocessing the images.
return ["from sklearn.preprocessing import MinMaxScaler"]
df = pd.read_csv(self.dataset_path, delimiter=';')
X = df.iloc[:, :-1]
y = df.iloc[:, -1]
self.scaler = MinMaxScaler()
X = self.scaler.fit_transform(X)
return DataManager(dataset=X, target=y, batch_size=batch_size, shuffle=True)
n_features = 18
n_classes = 2
model_args = { 'max_iter':1000, 'tol': 1e-1 ,
'n_features' : n_features, 'n_classes' : n_classes, 'loss': 'hinge'}
training_args = {
'num_updates': 5,
'batch_size': 128,
'dry_run': False,
Task 2: the Experiment #
The experiment enables Federated Learning by orchestrating the training process across multiple nodes. It searches for datasets based on specific tags, uploads the training plan file, sends model and training arguments, tracks and checks training progress, and downloads and aggregates model parameters for the next round.
TO_DO:
Define the tags to select the nodes
Define the used training plan.
Define the number of rounds for the federated process.
from fedbiomed.researcher.experiment import Experiment
from fedbiomed.researcher.aggregators.fedavg import FedAverage
tags = ['heart-jupyter-sharkovsky']
rounds = 10
# search for corresponding datasets across nodes datasets
exp = Experiment(tags=tags,
model_args=model_args,
training_plan_class=SkLearnClassifierTrainingPlan,
training_args=training_args,
round_limit=rounds,
aggregator=FedAverage(),
node_selection_strategy=None)
2023-07-03 14:38:00,927 fedbiomed INFO - Messaging researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87 successfully connected to the message broker, object = <fedbiomed.common.messaging.Messaging object at 0x7fce404c4b20>
2023-07-03 14:38:00,959 fedbiomed INFO - Searching dataset with data tags: ['heart-jupyter-sharkovsky'] for all nodes
2023-07-03 14:38:10,973 fedbiomed INFO - Node selected for training -> node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1
2023-07-03 14:38:10,974 fedbiomed INFO - Node selected for training -> node_10797f2f-2524-4595-a1c6-f3c67e03add1
2023-07-03 14:38:10,976 fedbiomed INFO - Checking data quality of federated datasets...
2023-07-03 14:38:10,977 fedbiomed DEBUG - Using native Sklearn Optimizer
2023-07-03 14:38:10,978 fedbiomed DEBUG - Model file has been saved: /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/my_model_8b48c219-cb97-4963-b035-4745618fca23.py
2023-07-03 14:38:11,071 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/my_model_8b48c219-cb97-4963-b035-4745618fca23.py successful, with status code 201
2023-07-03 14:38:11,080 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_b7de0161-57ad-4857-ac2b-bd5a43674bb6.mpk successful, with status code 201
2023-07-03 14:38:11,081 fedbiomed INFO - Removing tensorboard logs from previous experiment
# train experiments
exp.run()
2023-07-03 14:39:41,787 fedbiomed INFO - Sampled nodes in round 0 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:39:41,788 fedbiomed INFO - Sending request
To: node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 0, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_b7de0161-57ad-4857-ac2b-bd5a43674bb6.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_6dc88f60-68fb-4bc7-aa01-2f339ea0c08d'}
2023-07-03 14:39:41,788 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:39:41,789 fedbiomed INFO - Sending request
To: node_10797f2f-2524-4595-a1c6-f3c67e03add1
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 0, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_b7de0161-57ad-4857-ac2b-bd5a43674bb6.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_3fffa907-7569-46f0-a2b1-fa7245e42499', 'protocol_version': '1'}
2023-07-03 14:39:41,790 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:39:42,030 fedbiomed INFO - TRAINING
NODE_ID: node_10797f2f-2524-4595-a1c6-f3c67e03add1
Round 1 | Iteration: 1/5 (20%) | Samples: 128/640
Loss hinge: 1.000000
2023-07-03 14:39:42,031 fedbiomed INFO - TRAINING
NODE_ID: node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1
2023-07-03 14:39:42,053 fedbiomed INFO - TRAINING
Round 1 | Iteration: 3/5 (60%) | Samples: 349/640
Loss hinge: 1.006065
2023-07-03 14:39:42,057 fedbiomed INFO - TRAINING
Round 1 | Iteration: 4/5 (80%) | Samples: 391/640
Loss hinge: 1.852417
2023-07-03 14:39:42,076 fedbiomed INFO - TRAINING
Round 1 | Iteration: 5/5 (100%) | Samples: 519/640
Loss hinge: 3.580541
2023-07-03 14:39:42,078 fedbiomed INFO - TRAINING
Round 1 | Iteration: 4/5 (80%) | Samples: 477/640
Loss hinge: 4.077033
2023-07-03 14:39:42,093 fedbiomed INFO - TRAINING
Round 1 | Iteration: 5/5 (100%) | Samples: 605/640
Loss hinge: 3.068150
2023-07-03 14:39:51,806 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_d42587cb-dd29-460f-887a-910642918d60.mpk
2023-07-03 14:39:51,811 fedbiomed DEBUG - download of file node_params_79d8a21d-99a3-40cf-af83-11ed8868ec9a.mpk successful, with status code 200
2023-07-03 14:39:51,811 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_d84fbfc3-a23c-4195-b5bd-638143b4abac.mpk
2023-07-03 14:39:51,815 fedbiomed DEBUG - download of file node_params_182ef421-d214-40a3-ae8b-d2d4d3e9ceeb.mpk successful, with status code 200
2023-07-03 14:39:51,819 fedbiomed INFO - Nodes that successfully reply in round 0 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:39:51,828 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_c1adb784-b870-4b6d-bf3e-c6cec5578306.mpk successful, with status code 201
2023-07-03 14:39:51,828 fedbiomed INFO - Saved aggregated params for round 0 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_c1adb784-b870-4b6d-bf3e-c6cec5578306.mpk
2023-07-03 14:39:51,829 fedbiomed INFO - Sampled nodes in round 1 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:39:51,829 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 1, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_c1adb784-b870-4b6d-bf3e-c6cec5578306.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_6dc88f60-68fb-4bc7-aa01-2f339ea0c08d'}
2023-07-03 14:39:51,829 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:39:51,830 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 1, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_c1adb784-b870-4b6d-bf3e-c6cec5578306.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_3fffa907-7569-46f0-a2b1-fa7245e42499', 'protocol_version': '1'}
2023-07-03 14:39:51,830 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:39:51,864 fedbiomed INFO - TRAINING
Round 2 | Iteration: 1/5 (20%) | Samples: 128/640
Loss hinge: 1.049416
2023-07-03 14:39:51,865 fedbiomed INFO - TRAINING
Loss hinge: 1.027009
2023-07-03 14:39:51,899 fedbiomed INFO - TRAINING
Round 2 | Iteration: 3/5 (60%) | Samples: 349/640
Loss hinge: 1.063915
2023-07-03 14:39:51,904 fedbiomed INFO - TRAINING
Round 2 | Iteration: 4/5 (80%) | Samples: 391/640
Loss hinge: 1.911342
2023-07-03 14:39:51,923 fedbiomed INFO - TRAINING
Round 2 | Iteration: 5/5 (100%) | Samples: 519/640
Loss hinge: 2.797854
2023-07-03 14:39:51,924 fedbiomed INFO - TRAINING
Round 2 | Iteration: 4/5 (80%) | Samples: 477/640
Loss hinge: 0.870021
2023-07-03 14:39:51,939 fedbiomed INFO - TRAINING
Round 2 | Iteration: 5/5 (100%) | Samples: 605/640
Loss hinge: 1.679158
2023-07-03 14:40:01,843 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_18867bc3-13a0-43ec-9397-ba4d0b5b05b8.mpk
2023-07-03 14:40:01,848 fedbiomed DEBUG - download of file node_params_a6124a9a-5bfb-4549-b27c-cbf72f5e0d6c.mpk successful, with status code 200
2023-07-03 14:40:01,848 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_227d2e9f-8b09-45ba-bf96-b342bb22c144.mpk
2023-07-03 14:40:01,851 fedbiomed DEBUG - download of file node_params_7cba8c4d-bc05-4b41-acd7-f409f5b94d3a.mpk successful, with status code 200
2023-07-03 14:40:01,853 fedbiomed INFO - Nodes that successfully reply in round 1 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 14:40:01,863 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_c66687a0-6b7e-41ce-b9fc-7d05339bdc56.mpk successful, with status code 201
2023-07-03 14:40:01,863 fedbiomed INFO - Saved aggregated params for round 1 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_c66687a0-6b7e-41ce-b9fc-7d05339bdc56.mpk
2023-07-03 14:40:01,864 fedbiomed INFO - Sampled nodes in round 2 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:40:01,864 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 2, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_c66687a0-6b7e-41ce-b9fc-7d05339bdc56.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_6dc88f60-68fb-4bc7-aa01-2f339ea0c08d'}
2023-07-03 14:40:01,865 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:40:01,866 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 2, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_c66687a0-6b7e-41ce-b9fc-7d05339bdc56.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_3fffa907-7569-46f0-a2b1-fa7245e42499', 'protocol_version': '1'}
2023-07-03 14:40:01,867 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:40:01,899 fedbiomed INFO - TRAINING
Round 3 | Iteration: 1/5 (20%) | Samples: 128/640
Loss hinge: 1.172746
2023-07-03 14:40:01,942 fedbiomed INFO - TRAINING
Loss hinge: 1.089842
2023-07-03 14:40:01,943 fedbiomed INFO - TRAINING
Round 3 | Iteration: 4/5 (80%) | Samples: 391/640
Loss hinge: 0.969353
2023-07-03 14:40:01,946 fedbiomed INFO - TRAINING
Round 3 | Iteration: 3/5 (60%) | Samples: 349/640
Loss hinge: 0.823574
2023-07-03 14:40:01,956 fedbiomed INFO - TRAINING
Round 3 | Iteration: 5/5 (100%) | Samples: 519/640
Loss hinge: 5.964549
2023-07-03 14:40:01,965 fedbiomed INFO - TRAINING
Round 3 | Iteration: 4/5 (80%) | Samples: 477/640
Loss hinge: 1.420680
2023-07-03 14:40:01,985 fedbiomed INFO - TRAINING
Round 3 | Iteration: 5/5 (100%) | Samples: 605/640
Loss hinge: 1.777982
2023-07-03 14:40:11,876 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_8fbbaf35-845f-4a2f-af90-8ad0a3275401.mpk
2023-07-03 14:40:11,880 fedbiomed DEBUG - download of file node_params_e0f7c6dd-6c13-4eef-9ce4-981e6287212a.mpk successful, with status code 200
2023-07-03 14:40:11,881 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_6f5bfd2e-4e6d-4283-97dc-02b3b543e12e.mpk
2023-07-03 14:40:11,884 fedbiomed DEBUG - download of file node_params_f8b8c152-6cb0-439b-b141-d605b6a499e9.mpk successful, with status code 200
2023-07-03 14:40:11,885 fedbiomed INFO - Nodes that successfully reply in round 2 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:40:11,894 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_e02fc9ff-20e8-4065-8670-5a67fe6b7914.mpk successful, with status code 201
2023-07-03 14:40:11,894 fedbiomed INFO - Saved aggregated params for round 2 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_e02fc9ff-20e8-4065-8670-5a67fe6b7914.mpk
2023-07-03 14:40:11,895 fedbiomed INFO - Sampled nodes in round 3 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:40:11,895 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 3, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_e02fc9ff-20e8-4065-8670-5a67fe6b7914.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_6dc88f60-68fb-4bc7-aa01-2f339ea0c08d'}
2023-07-03 14:40:11,895 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:40:11,896 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 3, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_e02fc9ff-20e8-4065-8670-5a67fe6b7914.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_3fffa907-7569-46f0-a2b1-fa7245e42499', 'protocol_version': '1'}
2023-07-03 14:40:11,897 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:40:11,938 fedbiomed INFO - TRAINING
Round 4 | Iteration: 1/5 (20%) | Samples: 128/640
Loss hinge: 0.874855
2023-07-03 14:40:11,939 fedbiomed INFO - TRAINING
Loss hinge: 1.016869
2023-07-03 14:40:11,982 fedbiomed INFO - TRAINING
Round 4 | Iteration: 4/5 (80%) | Samples: 391/640
Loss hinge: 1.953992
2023-07-03 14:40:11,983 fedbiomed INFO - TRAINING
Round 4 | Iteration: 3/5 (60%) | Samples: 349/640
Loss hinge: 0.983414
2023-07-03 14:40:11,987 fedbiomed INFO - TRAINING
Round 4 | Iteration: 5/5 (100%) | Samples: 519/640
Loss hinge: 2.187833
2023-07-03 14:40:11,991 fedbiomed INFO - TRAINING
Round 4 | Iteration: 4/5 (80%) | Samples: 477/640
Loss hinge: 1.484909
2023-07-03 14:40:12,010 fedbiomed INFO - TRAINING
Round 4 | Iteration: 5/5 (100%) | Samples: 605/640
Loss hinge: 2.560063
2023-07-03 14:40:21,909 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_86313eb7-16fe-427e-b5d2-a2dca7d7520b.mpk
2023-07-03 14:40:21,913 fedbiomed DEBUG - download of file node_params_34662ed3-632e-42ef-9c22-fc909e7f7dc1.mpk successful, with status code 200
2023-07-03 14:40:21,913 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_9f2e0e27-43e6-4378-b983-48ccc61ebf53.mpk
2023-07-03 14:40:21,916 fedbiomed DEBUG - download of file node_params_ff111a95-edfe-4efa-91d4-d563f3149d7a.mpk successful, with status code 200
2023-07-03 14:40:21,918 fedbiomed INFO - Nodes that successfully reply in round 3 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:40:21,926 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_e2f557b0-ba8c-4190-a3fd-0d9a5400ee49.mpk successful, with status code 201
2023-07-03 14:40:21,927 fedbiomed INFO - Saved aggregated params for round 3 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_e2f557b0-ba8c-4190-a3fd-0d9a5400ee49.mpk
2023-07-03 14:40:21,927 fedbiomed INFO - Sampled nodes in round 4 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:40:21,927 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 4, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_e2f557b0-ba8c-4190-a3fd-0d9a5400ee49.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_6dc88f60-68fb-4bc7-aa01-2f339ea0c08d'}
2023-07-03 14:40:21,928 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:40:21,929 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 4, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_e2f557b0-ba8c-4190-a3fd-0d9a5400ee49.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_3fffa907-7569-46f0-a2b1-fa7245e42499', 'protocol_version': '1'}
2023-07-03 14:40:21,929 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:40:21,968 fedbiomed INFO - TRAINING
Round 5 | Iteration: 1/5 (20%) | Samples: 128/640
Loss hinge: 1.421098
2023-07-03 14:40:21,969 fedbiomed INFO - TRAINING
Loss hinge: 1.677845
2023-07-03 14:40:22,010 fedbiomed INFO - TRAINING
Round 5 | Iteration: 4/5 (80%) | Samples: 391/640
Loss hinge: 1.560698
Round 5 | Iteration: 3/5 (60%) | Samples: 349/640
Loss hinge: 1.570311
2023-07-03 14:40:22,020 fedbiomed INFO - TRAINING
Round 5 | Iteration: 5/5 (100%) | Samples: 519/640
Loss hinge: 2.906239
2023-07-03 14:40:22,023 fedbiomed INFO - TRAINING
Round 5 | Iteration: 4/5 (80%) | Samples: 477/640
Loss hinge: 1.144794
2023-07-03 14:40:22,042 fedbiomed INFO - TRAINING
Round 5 | Iteration: 5/5 (100%) | Samples: 605/640
Loss hinge: 1.139720
2023-07-03 14:40:31,941 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_dd9973c0-9fa0-4d01-adc2-f19aadcaa5fd.mpk
2023-07-03 14:40:31,945 fedbiomed DEBUG - download of file node_params_1ce2ab96-2a7e-43e7-9277-1c3bf1680518.mpk successful, with status code 200
2023-07-03 14:40:31,945 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_0f7907e3-e56b-4d9b-b6f7-e034cd6d351b.mpk
2023-07-03 14:40:31,948 fedbiomed DEBUG - download of file node_params_4326d6f7-895f-4cf6-af05-2b45473b6f6f.mpk successful, with status code 200
2023-07-03 14:40:31,950 fedbiomed INFO - Nodes that successfully reply in round 4 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:40:31,959 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_66b3d1f3-52f8-41be-bccc-be0240743d63.mpk successful, with status code 201
2023-07-03 14:40:31,959 fedbiomed INFO - Saved aggregated params for round 4 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_66b3d1f3-52f8-41be-bccc-be0240743d63.mpk
2023-07-03 14:40:31,960 fedbiomed INFO - Sampled nodes in round 5 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:40:31,960 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 5, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_66b3d1f3-52f8-41be-bccc-be0240743d63.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_6dc88f60-68fb-4bc7-aa01-2f339ea0c08d'}
2023-07-03 14:40:31,960 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:40:31,961 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 5, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_66b3d1f3-52f8-41be-bccc-be0240743d63.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_3fffa907-7569-46f0-a2b1-fa7245e42499', 'protocol_version': '1'}
2023-07-03 14:40:31,961 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:40:32,014 fedbiomed INFO - TRAINING
Round 6 | Iteration: 1/5 (20%) | Samples: 128/640
Loss hinge: 0.960151
2023-07-03 14:40:32,018 fedbiomed INFO - TRAINING
Loss hinge: 1.176058
2023-07-03 14:40:32,051 fedbiomed INFO - TRAINING
Round 6 | Iteration: 4/5 (80%) | Samples: 391/640
Loss hinge: 3.156323
2023-07-03 14:40:32,052 fedbiomed INFO - TRAINING
Round 6 | Iteration: 3/5 (60%) | Samples: 349/640
Loss hinge: 0.865018
2023-07-03 14:40:32,053 fedbiomed INFO - TRAINING
Round 6 | Iteration: 5/5 (100%) | Samples: 519/640
Loss hinge: 3.246942
2023-07-03 14:40:32,079 fedbiomed INFO - TRAINING
Round 6 | Iteration: 4/5 (80%) | Samples: 477/640
Loss hinge: 1.201610
2023-07-03 14:40:32,080 fedbiomed INFO - TRAINING
Round 6 | Iteration: 5/5 (100%) | Samples: 605/640
Loss hinge: 1.450477
2023-07-03 14:40:41,974 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_5328fe90-7ce9-455e-9cb1-d7018c8424df.mpk
2023-07-03 14:40:41,978 fedbiomed DEBUG - download of file node_params_101ae7c7-06fc-4c5f-8484-c1d8578e8e3d.mpk successful, with status code 200
2023-07-03 14:40:41,978 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_d2c4c801-1ce1-4fee-b9fd-7025d130932b.mpk
2023-07-03 14:40:41,981 fedbiomed DEBUG - download of file node_params_abdfd281-d477-4f70-b4eb-8eda46fcd2ef.mpk successful, with status code 200
2023-07-03 14:40:41,982 fedbiomed INFO - Nodes that successfully reply in round 5 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:40:41,991 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_08cc9313-21f1-4c35-b919-bcd0ec20a017.mpk successful, with status code 201
2023-07-03 14:40:41,992 fedbiomed INFO - Saved aggregated params for round 5 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_08cc9313-21f1-4c35-b919-bcd0ec20a017.mpk
2023-07-03 14:40:41,992 fedbiomed INFO - Sampled nodes in round 6 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:40:41,992 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 6, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_08cc9313-21f1-4c35-b919-bcd0ec20a017.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_6dc88f60-68fb-4bc7-aa01-2f339ea0c08d'}
2023-07-03 14:40:41,993 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:40:41,994 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 6, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_08cc9313-21f1-4c35-b919-bcd0ec20a017.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_3fffa907-7569-46f0-a2b1-fa7245e42499', 'protocol_version': '1'}
2023-07-03 14:40:41,994 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:40:42,041 fedbiomed INFO - TRAINING
Round 7 | Iteration: 1/5 (20%) | Samples: 128/640
Loss hinge: 1.332799
2023-07-03 14:40:42,042 fedbiomed INFO - TRAINING
Loss hinge: 1.287343
2023-07-03 14:40:42,082 fedbiomed INFO - TRAINING
Round 7 | Iteration: 4/5 (80%) | Samples: 391/640
Loss hinge: 0.000000
Round 7 | Iteration: 3/5 (60%) | Samples: 349/640
Loss hinge: 3.003612
2023-07-03 14:40:42,085 fedbiomed INFO - TRAINING
Round 7 | Iteration: 5/5 (100%) | Samples: 519/640
Loss hinge: 1.350821
2023-07-03 14:40:42,112 fedbiomed INFO - TRAINING
Round 7 | Iteration: 4/5 (80%) | Samples: 477/640
Loss hinge: 1.574242
Round 7 | Iteration: 5/5 (100%) | Samples: 605/640
Loss hinge: 1.177146
2023-07-03 14:40:52,006 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_7c4193d5-0545-440f-ba95-a3ca6f54b567.mpk
2023-07-03 14:40:52,010 fedbiomed DEBUG - download of file node_params_8152e0d4-d70c-4949-a46d-cae5184a58af.mpk successful, with status code 200
2023-07-03 14:40:52,011 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_38b37e72-dec3-4df1-9771-6a1954f6016d.mpk
2023-07-03 14:40:52,013 fedbiomed DEBUG - download of file node_params_e79562dc-2049-4038-bb28-ff96158484eb.mpk successful, with status code 200
2023-07-03 14:40:52,015 fedbiomed INFO - Nodes that successfully reply in round 6 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:40:52,023 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_9adf34fb-59ca-4107-b602-49e5c9fbc8f1.mpk successful, with status code 201
2023-07-03 14:40:52,024 fedbiomed INFO - Saved aggregated params for round 6 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_9adf34fb-59ca-4107-b602-49e5c9fbc8f1.mpk
2023-07-03 14:40:52,024 fedbiomed INFO - Sampled nodes in round 7 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:40:52,025 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 7, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_9adf34fb-59ca-4107-b602-49e5c9fbc8f1.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_6dc88f60-68fb-4bc7-aa01-2f339ea0c08d'}
2023-07-03 14:40:52,025 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:40:52,026 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 7, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_9adf34fb-59ca-4107-b602-49e5c9fbc8f1.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_3fffa907-7569-46f0-a2b1-fa7245e42499', 'protocol_version': '1'}
2023-07-03 14:40:52,026 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:40:52,069 fedbiomed INFO - TRAINING
Round 8 | Iteration: 1/5 (20%) | Samples: 128/640
Loss hinge: 1.074448
2023-07-03 14:40:52,070 fedbiomed INFO - TRAINING
Loss hinge: 0.741083
2023-07-03 14:40:52,110 fedbiomed INFO - TRAINING
Round 8 | Iteration: 4/5 (80%) | Samples: 391/640
Loss hinge: 1.501979
2023-07-03 14:40:52,111 fedbiomed INFO - TRAINING
Round 8 | Iteration: 3/5 (60%) | Samples: 349/640
Loss hinge: 1.574092
2023-07-03 14:40:52,117 fedbiomed INFO - TRAINING
Round 8 | Iteration: 5/5 (100%) | Samples: 519/640
Loss hinge: 2.381271
2023-07-03 14:40:52,122 fedbiomed INFO - TRAINING
Round 8 | Iteration: 4/5 (80%) | Samples: 477/640
Loss hinge: 2.232035
2023-07-03 14:40:52,141 fedbiomed INFO - TRAINING
Round 8 | Iteration: 5/5 (100%) | Samples: 605/640
Loss hinge: 2.495739
2023-07-03 14:41:02,038 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_809ca19c-99a4-4bda-803a-7d6741b1e7a1.mpk
2023-07-03 14:41:02,042 fedbiomed DEBUG - download of file node_params_8c22eda7-5d1c-4181-8657-afc804b15335.mpk successful, with status code 200
2023-07-03 14:41:02,043 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_3176c29b-8233-432f-beb5-5bc00389e4d2.mpk
2023-07-03 14:41:02,045 fedbiomed DEBUG - download of file node_params_4f79e57f-8f88-4e81-a39d-f40d7d255f8a.mpk successful, with status code 200
2023-07-03 14:41:02,047 fedbiomed INFO - Nodes that successfully reply in round 7 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:41:02,056 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_2b46701a-eb29-461a-bfd1-416223570a76.mpk successful, with status code 201
2023-07-03 14:41:02,056 fedbiomed INFO - Saved aggregated params for round 7 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_2b46701a-eb29-461a-bfd1-416223570a76.mpk
2023-07-03 14:41:02,056 fedbiomed INFO - Sampled nodes in round 8 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:41:02,057 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 8, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_2b46701a-eb29-461a-bfd1-416223570a76.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_6dc88f60-68fb-4bc7-aa01-2f339ea0c08d'}
2023-07-03 14:41:02,057 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:41:02,058 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 8, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_2b46701a-eb29-461a-bfd1-416223570a76.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_3fffa907-7569-46f0-a2b1-fa7245e42499', 'protocol_version': '1'}
2023-07-03 14:41:02,058 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:41:02,091 fedbiomed INFO - TRAINING
Round 9 | Iteration: 1/5 (20%) | Samples: 128/640
Loss hinge: 1.330070
2023-07-03 14:41:02,137 fedbiomed INFO - TRAINING
Loss hinge: 1.796861
2023-07-03 14:41:02,138 fedbiomed INFO - TRAINING
Round 9 | Iteration: 4/5 (80%) | Samples: 391/640
Loss hinge: 1.255121
2023-07-03 14:41:02,139 fedbiomed INFO - TRAINING
Round 9 | Iteration: 3/5 (60%) | Samples: 349/640
Loss hinge: 2.549095
2023-07-03 14:41:02,158 fedbiomed INFO - TRAINING
Round 9 | Iteration: 5/5 (100%) | Samples: 519/640
Loss hinge: 1.943776
Round 9 | Iteration: 4/5 (80%) | Samples: 477/640
Loss hinge: 0.770924
2023-07-03 14:41:02,198 fedbiomed INFO - TRAINING
Round 9 | Iteration: 5/5 (100%) | Samples: 605/640
Loss hinge: 1.308329
2023-07-03 14:41:12,070 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_b2c70cae-7bf3-407e-979b-5cee3291fc62.mpk
2023-07-03 14:41:12,074 fedbiomed DEBUG - download of file node_params_c248198b-60f0-4f7c-b333-33c5c8de43fa.mpk successful, with status code 200
2023-07-03 14:41:12,075 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_05161a57-768b-42c7-b76f-cc63666e5052.mpk
2023-07-03 14:41:12,077 fedbiomed DEBUG - download of file node_params_5c6b2079-5bf5-4260-9977-f1abbd3b4139.mpk successful, with status code 200
2023-07-03 14:41:12,079 fedbiomed INFO - Nodes that successfully reply in round 8 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:41:12,087 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_9b3da84a-606d-4689-8384-911c4656123d.mpk successful, with status code 201
2023-07-03 14:41:12,088 fedbiomed INFO - Saved aggregated params for round 8 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_9b3da84a-606d-4689-8384-911c4656123d.mpk
2023-07-03 14:41:12,088 fedbiomed INFO - Sampled nodes in round 9 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:41:12,088 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 9, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_9b3da84a-606d-4689-8384-911c4656123d.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_6dc88f60-68fb-4bc7-aa01-2f339ea0c08d'}
2023-07-03 14:41:12,089 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:41:12,090 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'fbcc50ad-d4a1-4528-b491-4d1a0bbd5b2f', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 9, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_8b48c219-cb97-4963-b035-4745618fca23.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_9b3da84a-606d-4689-8384-911c4656123d.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_3fffa907-7569-46f0-a2b1-fa7245e42499', 'protocol_version': '1'}
2023-07-03 14:41:12,090 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 14:41:12,130 fedbiomed INFO - TRAINING
Round 10 | Iteration: 1/5 (20%) | Samples: 128/640
Loss hinge: 0.886490
2023-07-03 14:41:12,131 fedbiomed INFO - TRAINING
Loss hinge: 0.704667
2023-07-03 14:41:12,174 fedbiomed INFO - TRAINING
Round 10 | Iteration: 4/5 (80%) | Samples: 391/640
Loss hinge: 3.202284
2023-07-03 14:41:12,175 fedbiomed INFO - TRAINING
Round 10 | Iteration: 3/5 (60%) | Samples: 349/640
Loss hinge: 0.827798
2023-07-03 14:41:12,181 fedbiomed INFO - TRAINING
Round 10 | Iteration: 5/5 (100%) | Samples: 519/640
Loss hinge: 10.244533
2023-07-03 14:41:12,183 fedbiomed INFO - TRAINING
Round 10 | Iteration: 4/5 (80%) | Samples: 477/640
Loss hinge: 1.449496
2023-07-03 14:41:12,202 fedbiomed INFO - TRAINING
Round 10 | Iteration: 5/5 (100%) | Samples: 605/640
Loss hinge: 3.531648
2023-07-03 14:41:22,102 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_5417d5e1-5850-4473-81a3-5c42fdc8c7b7.mpk
2023-07-03 14:41:22,106 fedbiomed DEBUG - download of file node_params_1c0634dc-8f5e-4082-acea-bc297ab46452.mpk successful, with status code 200
2023-07-03 14:41:22,107 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_cbf71f9b-ecd0-4922-bc78-a7fb7f2eee81.mpk
2023-07-03 14:41:22,110 fedbiomed DEBUG - download of file node_params_bd17ee53-2501-4e5e-a572-115d610dc49d.mpk successful, with status code 200
2023-07-03 14:41:22,111 fedbiomed INFO - Nodes that successfully reply in round 9 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 14:41:22,123 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_2ff74778-3640-470d-8657-185b0dd76a3e.mpk successful, with status code 201
2023-07-03 14:41:22,123 fedbiomed INFO - Saved aggregated params for round 9 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0032/aggregated_params_2ff74778-3640-470d-8657-185b0dd76a3e.mpk
10
Task 3: Model Validation #
During federated training, model validation plays a crucial role in assessing performance without a dedicated holdout dataset. Fed-BioMed enables separate model validation on each node after parameter updates, allowing comparison of model performances. Two types of validation can be performed:
one on globally updated parameters before training a round,
another on locally updated parameters after local training is completed on a node.
This helps users evaluate the impact of node-specific training on model improvement.
Here is the list of validation arguments that can be configured.
test_ratio: Ratio of the validation partition of the dataset. The remaining samples will be used for training. By default, it is 0.0.
test_on_global_updates: Boolean value that indicates whether validation will be applied to globally updated (aggregated) parameters (see Figure 1). Default is False
test_on_local_updates: Boolean value that indicates whether validation will be applied to locally updated (trained) parameters (see Figure 1). Default is False
test_metric: One of MetricTypes that indicates which metric will be used for validation. It can be str or an instance of MetricTypes (e.g. MetricTypes.RECALL or RECALL ). If it is None and there isn’t testing_step defined in the training plan (see section: Define Custom Validation Step) default metric will be ACCURACY.
test_metric_args: A dictionary that contains the arguments that will be used for the metric function.
TO_DO:
Initialize a new experiements.
Use the setters to define the validation arguments.
Launch the training and check the validation performances.
round_limit=rounds,
exp.set_test_ratio(0.10)
exp.set_test_on_local_updates(True)
exp.set_test_on_global_updates(True)
exp.set_test_metric('F1_SCORE')
2023-07-03 13:09:00,198 fedbiomed INFO - Searching dataset with data tags: ['heart'] for all nodes
2023-07-03 13:09:10,211 fedbiomed INFO - Node selected for training -> node_1c6bdcb7-99e7-4278-95c9-98caeda6971b
2023-07-03 13:09:10,212 fedbiomed INFO - Node selected for training -> node_8641a287-262f-40cb-a01d-0b17f5c76e2e
2023-07-03 13:09:10,214 fedbiomed INFO - Checking data quality of federated datasets...
2023-07-03 13:09:10,215 fedbiomed DEBUG - Using native Sklearn Optimizer
2023-07-03 13:09:10,217 fedbiomed DEBUG - Model file has been saved: /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py
2023-07-03 13:09:10,233 fedbiomed DEBUG - HTTP POST request of file /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py successful, with status code 201
2023-07-03 13:09:10,253 fedbiomed DEBUG - HTTP POST request of file /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_c63bc355-b053-443c-95cd-25eb2ab66237.mpk successful, with status code 201
2023-07-03 13:09:10,256 fedbiomed DEBUG - Experimentation training_args updated for `job`
2023-07-03 13:09:10,257 fedbiomed DEBUG - Experimentation training_args updated for `job`
2023-07-03 13:09:10,259 fedbiomed DEBUG - Experimentation training_args updated for `job`
2023-07-03 13:09:10,260 fedbiomed DEBUG - Experimentation training_args updated for `job`
('F1_SCORE', {})
exp.training_args()
{'num_updates': 5,
'batch_size': 128,
'dry_run': False,
'epochs': None,
'test_ratio': 0.1,
'test_on_local_updates': True,
'test_on_global_updates': True,
'test_metric': 'F1_SCORE',
'log_interval': 10,
'fedprox_mu': None,
'use_gpu': False,
'dp_args': None,
exp.run()
2023-07-03 13:10:47,594 fedbiomed INFO - Sampled nodes in round 0 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:10:47,595 fedbiomed INFO - Sending request
To: node_1c6bdcb7-99e7-4278-95c9-98caeda6971b
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 0, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_c63bc355-b053-443c-95cd-25eb2ab66237.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_73474707-cfad-4e6a-b585-9a3520fdd776'}
2023-07-03 13:10:47,597 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:10:47,599 fedbiomed INFO - Sending request
To: node_8641a287-262f-40cb-a01d-0b17f5c76e2e
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 0, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_c63bc355-b053-443c-95cd-25eb2ab66237.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_d45526f2-d699-4b64-8934-90d06d77967a', 'protocol_version': '1'}
2023-07-03 13:10:47,600 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:10:47,628 fedbiomed INFO - INFO
NODE node_1c6bdcb7-99e7-4278-95c9-98caeda6971b
MESSAGE: NPDataLoader expanding 1-dimensional target to become 2-dimensional.
2023-07-03 13:10:47,660 fedbiomed INFO - INFO
NODE node_8641a287-262f-40cb-a01d-0b17f5c76e2e
2023-07-03 13:10:47,701 fedbiomed INFO - INFO
2023-07-03 13:10:47,703 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
NODE_ID: node_1c6bdcb7-99e7-4278-95c9-98caeda6971b
Round 1 | Iteration: 1/1 (100%) | Samples: 40/40
F1_SCORE: 0.620690
2023-07-03 13:10:47,705 fedbiomed INFO - TRAINING
2023-07-03 13:10:47,709 fedbiomed INFO - INFO
2023-07-03 13:10:47,717 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
NODE_ID: node_8641a287-262f-40cb-a01d-0b17f5c76e2e
Round 1 | Iteration: 1/1 (100%) | Samples: 35/35
F1_SCORE: 0.541667
2023-07-03 13:10:47,763 fedbiomed INFO - TRAINING
2023-07-03 13:10:47,820 fedbiomed INFO - TRAINING
Round 1 | Iteration: 3/5 (60%) | Samples: 351/640
Loss hinge: 0.646654
2023-07-03 13:10:47,848 fedbiomed INFO - TRAINING
Round 1 | Iteration: 3/5 (60%) | Samples: 314/640
Loss hinge: 0.874489
2023-07-03 13:10:47,873 fedbiomed INFO - TRAINING
Round 1 | Iteration: 4/5 (80%) | Samples: 479/640
Loss hinge: 1.070804
2023-07-03 13:10:47,899 fedbiomed INFO - TRAINING
Round 1 | Iteration: 4/5 (80%) | Samples: 442/640
Loss hinge: 0.961074
2023-07-03 13:10:47,940 fedbiomed INFO - TRAINING
Round 1 | Iteration: 5/5 (100%) | Samples: 607/640
Loss hinge: 3.185373
2023-07-03 13:10:47,942 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.654545
2023-07-03 13:10:47,962 fedbiomed INFO - INFO
MESSAGE: results uploaded successfully
2023-07-03 13:10:47,965 fedbiomed INFO - TRAINING
Round 1 | Iteration: 5/5 (100%) | Samples: 570/640
Loss hinge: 3.339485
2023-07-03 13:10:47,967 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.000000
2023-07-03 13:10:47,991 fedbiomed INFO - INFO
2023-07-03 13:10:57,619 fedbiomed INFO - Downloading model params after training on node_1c6bdcb7-99e7-4278-95c9-98caeda6971b - from http://localhost:8844/media/uploads/2023/07/03/node_params_a851d235-e20b-485f-b5f3-ef256fce6e94.mpk
2023-07-03 13:10:57,624 fedbiomed DEBUG - download of file node_params_087d00eb-43dc-4f0a-acf2-06773c51b403.mpk successful, with status code 200
2023-07-03 13:10:57,626 fedbiomed INFO - Downloading model params after training on node_8641a287-262f-40cb-a01d-0b17f5c76e2e - from http://localhost:8844/media/uploads/2023/07/03/node_params_bfc19c75-168f-4f5f-b694-a2241d595e72.mpk
2023-07-03 13:10:57,633 fedbiomed DEBUG - download of file node_params_549a8218-017f-4785-92ac-d5bbeda56bf3.mpk successful, with status code 200
2023-07-03 13:10:57,638 fedbiomed INFO - Nodes that successfully reply in round 0 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:10:57,666 fedbiomed DEBUG - HTTP POST request of file /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_da8e3b9e-a27a-499e-ad3d-d8a2bd60f2e7.mpk successful, with status code 201
2023-07-03 13:10:57,668 fedbiomed INFO - Saved aggregated params for round 0 in /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_da8e3b9e-a27a-499e-ad3d-d8a2bd60f2e7.mpk
2023-07-03 13:10:57,669 fedbiomed INFO - Sampled nodes in round 1 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:10:57,671 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 1, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_da8e3b9e-a27a-499e-ad3d-d8a2bd60f2e7.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_73474707-cfad-4e6a-b585-9a3520fdd776'}
2023-07-03 13:10:57,672 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:10:57,674 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 1, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_da8e3b9e-a27a-499e-ad3d-d8a2bd60f2e7.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_d45526f2-d699-4b64-8934-90d06d77967a', 'protocol_version': '1'}
2023-07-03 13:10:57,676 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:10:57,711 fedbiomed INFO - INFO
2023-07-03 13:10:57,751 fedbiomed INFO - INFO
2023-07-03 13:10:57,756 fedbiomed INFO - INFO
2023-07-03 13:10:57,758 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 2 | Iteration: 1/1 (100%) | Samples: 40/40
F1_SCORE: 0.650000
2023-07-03 13:10:57,760 fedbiomed INFO - INFO
2023-07-03 13:10:57,761 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 2 | Iteration: 1/1 (100%) | Samples: 35/35
F1_SCORE: 0.814815
2023-07-03 13:10:57,799 fedbiomed INFO - TRAINING
Loss hinge: 0.571441
2023-07-03 13:10:57,813 fedbiomed INFO - TRAINING
Loss hinge: 0.826935
2023-07-03 13:10:57,891 fedbiomed INFO - TRAINING
Round 2 | Iteration: 3/5 (60%) | Samples: 351/640
Loss hinge: 1.080854
2023-07-03 13:10:57,908 fedbiomed INFO - TRAINING
Round 2 | Iteration: 3/5 (60%) | Samples: 314/640
Loss hinge: 5.621247
2023-07-03 13:10:57,948 fedbiomed INFO - TRAINING
Round 2 | Iteration: 4/5 (80%) | Samples: 479/640
Loss hinge: 3.503852
2023-07-03 13:10:57,971 fedbiomed INFO - TRAINING
Round 2 | Iteration: 4/5 (80%) | Samples: 442/640
Loss hinge: 3.111656
2023-07-03 13:10:58,000 fedbiomed INFO - TRAINING
Round 2 | Iteration: 5/5 (100%) | Samples: 607/640
Loss hinge: 3.101825
2023-07-03 13:10:58,006 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.666667
2023-07-03 13:10:58,036 fedbiomed INFO - TRAINING
Round 2 | Iteration: 5/5 (100%) | Samples: 570/640
Loss hinge: 2.136677
2023-07-03 13:10:58,046 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.769231
2023-07-03 13:10:58,056 fedbiomed INFO - INFO
2023-07-03 13:10:58,077 fedbiomed INFO - INFO
2023-07-03 13:11:07,696 fedbiomed INFO - Downloading model params after training on node_1c6bdcb7-99e7-4278-95c9-98caeda6971b - from http://localhost:8844/media/uploads/2023/07/03/node_params_01298da2-5f69-44bd-a3fb-a79d1c3a3b8b.mpk
2023-07-03 13:11:07,703 fedbiomed DEBUG - download of file node_params_f9d00178-e37a-4711-91c1-452364324219.mpk successful, with status code 200
2023-07-03 13:11:07,705 fedbiomed INFO - Downloading model params after training on node_8641a287-262f-40cb-a01d-0b17f5c76e2e - from http://localhost:8844/media/uploads/2023/07/03/node_params_4fbd15b3-06d2-4f99-834b-71b026f910be.mpk
2023-07-03 13:11:07,714 fedbiomed DEBUG - download of file node_params_0764d423-ba75-4eec-8fac-e01490bad39c.mpk successful, with status code 200
2023-07-03 13:11:07,718 fedbiomed INFO - Nodes that successfully reply in round 1 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:11:07,745 fedbiomed DEBUG - HTTP POST request of file /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_f2749202-bb4a-4289-8dca-c370b43795ce.mpk successful, with status code 201
2023-07-03 13:11:07,746 fedbiomed INFO - Saved aggregated params for round 1 in /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_f2749202-bb4a-4289-8dca-c370b43795ce.mpk
2023-07-03 13:11:07,747 fedbiomed INFO - Sampled nodes in round 2 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:11:07,747 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 2, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_f2749202-bb4a-4289-8dca-c370b43795ce.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_73474707-cfad-4e6a-b585-9a3520fdd776'}
2023-07-03 13:11:07,748 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:11:07,750 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 2, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_f2749202-bb4a-4289-8dca-c370b43795ce.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_d45526f2-d699-4b64-8934-90d06d77967a', 'protocol_version': '1'}
2023-07-03 13:11:07,751 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:11:07,790 fedbiomed INFO - INFO
2023-07-03 13:11:07,792 fedbiomed INFO - INFO
2023-07-03 13:11:07,831 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 3 | Iteration: 1/1 (100%) | Samples: 40/40
F1_SCORE: 0.723404
2023-07-03 13:11:07,833 fedbiomed INFO - INFO
2023-07-03 13:11:07,834 fedbiomed INFO - INFO
2023-07-03 13:11:07,837 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 3 | Iteration: 1/1 (100%) | Samples: 35/35
F1_SCORE: 0.750000
2023-07-03 13:11:07,854 fedbiomed INFO - TRAINING
Loss hinge: 0.847779
2023-07-03 13:11:07,893 fedbiomed INFO - TRAINING
Loss hinge: 0.976905
2023-07-03 13:11:07,952 fedbiomed INFO - TRAINING
Round 3 | Iteration: 3/5 (60%) | Samples: 351/640
Loss hinge: 1.424982
2023-07-03 13:11:07,975 fedbiomed INFO - TRAINING
Round 3 | Iteration: 3/5 (60%) | Samples: 314/640
Loss hinge: 1.831711
2023-07-03 13:11:08,010 fedbiomed INFO - TRAINING
Round 3 | Iteration: 4/5 (80%) | Samples: 479/640
Loss hinge: 0.862112
2023-07-03 13:11:08,042 fedbiomed INFO - TRAINING
Round 3 | Iteration: 4/5 (80%) | Samples: 442/640
Loss hinge: 1.656498
2023-07-03 13:11:08,082 fedbiomed INFO - TRAINING
Round 3 | Iteration: 5/5 (100%) | Samples: 607/640
Loss hinge: 0.762910
2023-07-03 13:11:08,087 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.756757
2023-07-03 13:11:08,116 fedbiomed INFO - INFO
2023-07-03 13:11:08,120 fedbiomed INFO - TRAINING
Round 3 | Iteration: 5/5 (100%) | Samples: 570/640
Loss hinge: 1.686199
2023-07-03 13:11:08,125 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.666667
2023-07-03 13:11:08,151 fedbiomed INFO - INFO
2023-07-03 13:11:17,770 fedbiomed INFO - Downloading model params after training on node_1c6bdcb7-99e7-4278-95c9-98caeda6971b - from http://localhost:8844/media/uploads/2023/07/03/node_params_e2048bb7-4666-4b16-82e2-6b61a4dc9c9b.mpk
2023-07-03 13:11:17,779 fedbiomed DEBUG - download of file node_params_467cd333-c31b-486d-be19-7a330f059e66.mpk successful, with status code 200
2023-07-03 13:11:17,780 fedbiomed INFO - Downloading model params after training on node_8641a287-262f-40cb-a01d-0b17f5c76e2e - from http://localhost:8844/media/uploads/2023/07/03/node_params_50e22a77-5eee-473e-a1ff-afc72d6c5317.mpk
2023-07-03 13:11:17,788 fedbiomed DEBUG - download of file node_params_1a214c29-9dab-4e99-a94a-c601964d06c8.mpk successful, with status code 200
2023-07-03 13:11:17,790 fedbiomed INFO - Nodes that successfully reply in round 2 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:11:17,816 fedbiomed DEBUG - HTTP POST request of file /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_b325e05d-1e8d-4806-bb12-b3c95be8fb56.mpk successful, with status code 201
2023-07-03 13:11:17,817 fedbiomed INFO - Saved aggregated params for round 2 in /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_b325e05d-1e8d-4806-bb12-b3c95be8fb56.mpk
2023-07-03 13:11:17,818 fedbiomed INFO - Sampled nodes in round 3 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:11:17,818 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 3, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_b325e05d-1e8d-4806-bb12-b3c95be8fb56.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_73474707-cfad-4e6a-b585-9a3520fdd776'}
2023-07-03 13:11:17,819 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:11:17,821 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 3, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_b325e05d-1e8d-4806-bb12-b3c95be8fb56.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_d45526f2-d699-4b64-8934-90d06d77967a', 'protocol_version': '1'}
2023-07-03 13:11:17,822 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:11:17,851 fedbiomed INFO - INFO
2023-07-03 13:11:17,853 fedbiomed INFO - INFO
2023-07-03 13:11:17,892 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 4 | Iteration: 1/1 (100%) | Samples: 40/40
F1_SCORE: 0.880000
2023-07-03 13:11:17,894 fedbiomed INFO - INFO
2023-07-03 13:11:17,928 fedbiomed INFO - TRAINING
Loss hinge: 1.110141
2023-07-03 13:11:17,930 fedbiomed INFO - INFO
2023-07-03 13:11:17,932 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 4 | Iteration: 1/1 (100%) | Samples: 35/35
F1_SCORE: 0.722222
2023-07-03 13:11:17,958 fedbiomed INFO - TRAINING
Loss hinge: 0.788128
2023-07-03 13:11:18,035 fedbiomed INFO - TRAINING
Round 4 | Iteration: 3/5 (60%) | Samples: 351/640
Loss hinge: 1.704669
2023-07-03 13:11:18,045 fedbiomed INFO - TRAINING
Round 4 | Iteration: 3/5 (60%) | Samples: 314/640
Loss hinge: 2.378920
2023-07-03 13:11:18,097 fedbiomed INFO - TRAINING
Round 4 | Iteration: 4/5 (80%) | Samples: 479/640
Loss hinge: 3.010502
2023-07-03 13:11:18,102 fedbiomed INFO - TRAINING
Round 4 | Iteration: 4/5 (80%) | Samples: 442/640
Loss hinge: 1.556234
2023-07-03 13:11:18,156 fedbiomed INFO - TRAINING
Round 4 | Iteration: 5/5 (100%) | Samples: 607/640
Loss hinge: 3.040663
2023-07-03 13:11:18,160 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.900000
2023-07-03 13:11:18,162 fedbiomed INFO - TRAINING
Round 4 | Iteration: 5/5 (100%) | Samples: 570/640
Loss hinge: 1.326774
2023-07-03 13:11:18,166 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.755556
2023-07-03 13:11:18,189 fedbiomed INFO - INFO
2023-07-03 13:11:18,205 fedbiomed INFO - INFO
2023-07-03 13:11:27,839 fedbiomed INFO - Downloading model params after training on node_1c6bdcb7-99e7-4278-95c9-98caeda6971b - from http://localhost:8844/media/uploads/2023/07/03/node_params_3f0dfc90-78b6-44b6-80ff-02e4ec5c1893.mpk
2023-07-03 13:11:27,845 fedbiomed DEBUG - download of file node_params_7b7a3d7f-f590-463c-8254-e41e0d714867.mpk successful, with status code 200
2023-07-03 13:11:27,847 fedbiomed INFO - Downloading model params after training on node_8641a287-262f-40cb-a01d-0b17f5c76e2e - from http://localhost:8844/media/uploads/2023/07/03/node_params_fd0a41e2-e711-41a6-816e-aa1cba5257b6.mpk
2023-07-03 13:11:27,855 fedbiomed DEBUG - download of file node_params_c1b91ec8-b0a6-4df4-9298-855defddc08a.mpk successful, with status code 200
2023-07-03 13:11:27,858 fedbiomed INFO - Nodes that successfully reply in round 3 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:11:27,888 fedbiomed DEBUG - HTTP POST request of file /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_184fa830-c29d-411c-a289-0ade92732955.mpk successful, with status code 201
2023-07-03 13:11:27,890 fedbiomed INFO - Saved aggregated params for round 3 in /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_184fa830-c29d-411c-a289-0ade92732955.mpk
2023-07-03 13:11:27,892 fedbiomed INFO - Sampled nodes in round 4 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:11:27,893 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 4, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_184fa830-c29d-411c-a289-0ade92732955.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_73474707-cfad-4e6a-b585-9a3520fdd776'}
2023-07-03 13:11:27,894 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:11:27,896 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 4, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_184fa830-c29d-411c-a289-0ade92732955.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_d45526f2-d699-4b64-8934-90d06d77967a', 'protocol_version': '1'}
2023-07-03 13:11:27,897 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:11:27,932 fedbiomed INFO - INFO
2023-07-03 13:11:27,934 fedbiomed INFO - INFO
2023-07-03 13:11:27,975 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 5 | Iteration: 1/1 (100%) | Samples: 40/40
F1_SCORE: 0.840000
2023-07-03 13:11:27,977 fedbiomed INFO - INFO
2023-07-03 13:11:27,979 fedbiomed INFO - INFO
2023-07-03 13:11:27,981 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 5 | Iteration: 1/1 (100%) | Samples: 35/35
F1_SCORE: 0.717949
2023-07-03 13:11:28,017 fedbiomed INFO - TRAINING
Loss hinge: 1.220582
2023-07-03 13:11:28,051 fedbiomed INFO - TRAINING
Loss hinge: 1.791132
2023-07-03 13:11:28,139 fedbiomed INFO - TRAINING
Round 5 | Iteration: 3/5 (60%) | Samples: 351/640
Loss hinge: 0.935866
2023-07-03 13:11:28,148 fedbiomed INFO - TRAINING
Round 5 | Iteration: 3/5 (60%) | Samples: 314/640
Loss hinge: 1.739728
2023-07-03 13:11:28,203 fedbiomed INFO - TRAINING
Round 5 | Iteration: 4/5 (80%) | Samples: 479/640
Loss hinge: 1.499985
2023-07-03 13:11:28,210 fedbiomed INFO - TRAINING
Round 5 | Iteration: 4/5 (80%) | Samples: 442/640
Loss hinge: 1.843874
2023-07-03 13:11:28,256 fedbiomed INFO - TRAINING
Round 5 | Iteration: 5/5 (100%) | Samples: 607/640
Loss hinge: 1.393408
2023-07-03 13:11:28,257 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.647059
2023-07-03 13:11:28,259 fedbiomed INFO - TRAINING
Round 5 | Iteration: 5/5 (100%) | Samples: 570/640
Loss hinge: 1.451019
2023-07-03 13:11:28,265 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.750000
2023-07-03 13:11:28,282 fedbiomed INFO - INFO
2023-07-03 13:11:28,292 fedbiomed INFO - INFO
2023-07-03 13:11:37,917 fedbiomed INFO - Downloading model params after training on node_1c6bdcb7-99e7-4278-95c9-98caeda6971b - from http://localhost:8844/media/uploads/2023/07/03/node_params_5abd9e05-6407-4216-8ac4-e0c14b226afa.mpk
2023-07-03 13:11:37,925 fedbiomed DEBUG - download of file node_params_911e8f78-bc17-46bd-9d4e-f5a072d9db2c.mpk successful, with status code 200
2023-07-03 13:11:37,927 fedbiomed INFO - Downloading model params after training on node_8641a287-262f-40cb-a01d-0b17f5c76e2e - from http://localhost:8844/media/uploads/2023/07/03/node_params_107c9cca-8051-4a9d-8c83-095453773d1b.mpk
2023-07-03 13:11:37,936 fedbiomed DEBUG - download of file node_params_d935363b-2f26-4775-ad88-3a76c0997939.mpk successful, with status code 200
2023-07-03 13:11:37,941 fedbiomed INFO - Nodes that successfully reply in round 4 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:11:37,972 fedbiomed DEBUG - HTTP POST request of file /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_149700c9-f09e-4f2b-b59f-3cf8ca9dda9f.mpk successful, with status code 201
2023-07-03 13:11:37,973 fedbiomed INFO - Saved aggregated params for round 4 in /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_149700c9-f09e-4f2b-b59f-3cf8ca9dda9f.mpk
2023-07-03 13:11:37,974 fedbiomed INFO - Sampled nodes in round 5 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:11:37,975 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 5, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_149700c9-f09e-4f2b-b59f-3cf8ca9dda9f.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_73474707-cfad-4e6a-b585-9a3520fdd776'}
2023-07-03 13:11:37,976 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:11:37,977 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 5, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_149700c9-f09e-4f2b-b59f-3cf8ca9dda9f.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_d45526f2-d699-4b64-8934-90d06d77967a', 'protocol_version': '1'}
2023-07-03 13:11:37,978 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:11:38,016 fedbiomed INFO - INFO
2023-07-03 13:11:38,019 fedbiomed INFO - INFO
2023-07-03 13:11:38,059 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 6 | Iteration: 1/1 (100%) | Samples: 40/40
F1_SCORE: 0.740741
2023-07-03 13:11:38,060 fedbiomed INFO - INFO
2023-07-03 13:11:38,062 fedbiomed INFO - INFO
2023-07-03 13:11:38,064 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 6 | Iteration: 1/1 (100%) | Samples: 35/35
F1_SCORE: 0.774194
2023-07-03 13:11:38,083 fedbiomed INFO - TRAINING
Loss hinge: 1.168365
2023-07-03 13:11:38,122 fedbiomed INFO - TRAINING
Loss hinge: 1.097516
2023-07-03 13:11:38,187 fedbiomed INFO - TRAINING
Round 6 | Iteration: 3/5 (60%) | Samples: 351/640
Loss hinge: 1.427672
2023-07-03 13:11:38,214 fedbiomed INFO - TRAINING
Round 6 | Iteration: 3/5 (60%) | Samples: 314/640
Loss hinge: 1.031782
2023-07-03 13:11:38,251 fedbiomed INFO - TRAINING
Round 6 | Iteration: 4/5 (80%) | Samples: 479/640
Loss hinge: 2.022977
2023-07-03 13:11:38,270 fedbiomed INFO - TRAINING
Round 6 | Iteration: 4/5 (80%) | Samples: 442/640
Loss hinge: 2.552519
2023-07-03 13:11:38,309 fedbiomed INFO - TRAINING
Round 6 | Iteration: 5/5 (100%) | Samples: 607/640
Loss hinge: 2.463381
2023-07-03 13:11:38,314 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.756757
2023-07-03 13:11:38,325 fedbiomed INFO - TRAINING
Round 6 | Iteration: 5/5 (100%) | Samples: 570/640
Loss hinge: 3.149643
2023-07-03 13:11:38,327 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.545455
2023-07-03 13:11:38,337 fedbiomed INFO - INFO
2023-07-03 13:11:38,347 fedbiomed INFO - INFO
2023-07-03 13:11:47,996 fedbiomed INFO - Downloading model params after training on node_1c6bdcb7-99e7-4278-95c9-98caeda6971b - from http://localhost:8844/media/uploads/2023/07/03/node_params_8051ef50-58f1-431b-ba61-fa2a7de4425e.mpk
2023-07-03 13:11:48,003 fedbiomed DEBUG - download of file node_params_eb0d8cf1-796c-441f-be19-3efb7ec9a348.mpk successful, with status code 200
2023-07-03 13:11:48,005 fedbiomed INFO - Downloading model params after training on node_8641a287-262f-40cb-a01d-0b17f5c76e2e - from http://localhost:8844/media/uploads/2023/07/03/node_params_23b6ff12-0114-4d39-b611-5407b97a298c.mpk
2023-07-03 13:11:48,014 fedbiomed DEBUG - download of file node_params_96e1f4da-2feb-43d2-b739-aec6f9470a64.mpk successful, with status code 200
2023-07-03 13:11:48,018 fedbiomed INFO - Nodes that successfully reply in round 5 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:11:48,044 fedbiomed DEBUG - HTTP POST request of file /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_1e4efd08-3675-4c18-a8d8-71ee656cf2e4.mpk successful, with status code 201
2023-07-03 13:11:48,045 fedbiomed INFO - Saved aggregated params for round 5 in /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_1e4efd08-3675-4c18-a8d8-71ee656cf2e4.mpk
2023-07-03 13:11:48,046 fedbiomed INFO - Sampled nodes in round 6 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:11:48,047 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 6, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_1e4efd08-3675-4c18-a8d8-71ee656cf2e4.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_73474707-cfad-4e6a-b585-9a3520fdd776'}
2023-07-03 13:11:48,047 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:11:48,048 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 6, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_1e4efd08-3675-4c18-a8d8-71ee656cf2e4.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_d45526f2-d699-4b64-8934-90d06d77967a', 'protocol_version': '1'}
2023-07-03 13:11:48,049 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:11:48,075 fedbiomed INFO - INFO
2023-07-03 13:11:48,077 fedbiomed INFO - INFO
2023-07-03 13:11:48,112 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 7 | Iteration: 1/1 (100%) | Samples: 40/40
F1_SCORE: 0.685714
2023-07-03 13:11:48,114 fedbiomed INFO - INFO
2023-07-03 13:11:48,115 fedbiomed INFO - INFO
2023-07-03 13:11:48,118 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 7 | Iteration: 1/1 (100%) | Samples: 35/35
F1_SCORE: 0.722222
2023-07-03 13:11:48,157 fedbiomed INFO - TRAINING
Loss hinge: 1.142721
2023-07-03 13:11:48,193 fedbiomed INFO - TRAINING
Loss hinge: 1.086165
2023-07-03 13:11:48,289 fedbiomed INFO - TRAINING
Round 7 | Iteration: 3/5 (60%) | Samples: 351/640
Loss hinge: 0.863901
2023-07-03 13:11:48,304 fedbiomed INFO - TRAINING
Round 7 | Iteration: 3/5 (60%) | Samples: 314/640
Loss hinge: 0.980729
2023-07-03 13:11:48,361 fedbiomed INFO - TRAINING
Round 7 | Iteration: 4/5 (80%) | Samples: 479/640
Loss hinge: 1.270667
2023-07-03 13:11:48,375 fedbiomed INFO - TRAINING
Round 7 | Iteration: 4/5 (80%) | Samples: 442/640
Loss hinge: 1.046473
2023-07-03 13:11:48,436 fedbiomed INFO - TRAINING
Round 7 | Iteration: 5/5 (100%) | Samples: 607/640
Loss hinge: 0.967612
2023-07-03 13:11:48,438 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.652174
2023-07-03 13:11:48,448 fedbiomed INFO - TRAINING
Round 7 | Iteration: 5/5 (100%) | Samples: 570/640
Loss hinge: 1.025577
2023-07-03 13:11:48,449 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.818182
2023-07-03 13:11:48,463 fedbiomed INFO - INFO
2023-07-03 13:11:48,473 fedbiomed INFO - INFO
2023-07-03 13:11:58,062 fedbiomed INFO - Downloading model params after training on node_1c6bdcb7-99e7-4278-95c9-98caeda6971b - from http://localhost:8844/media/uploads/2023/07/03/node_params_91cb60c3-262f-4462-b47c-46b168b222ad.mpk
2023-07-03 13:11:58,069 fedbiomed DEBUG - download of file node_params_6578107f-179c-4a8e-805f-0b6577afcf02.mpk successful, with status code 200
2023-07-03 13:11:58,071 fedbiomed INFO - Downloading model params after training on node_8641a287-262f-40cb-a01d-0b17f5c76e2e - from http://localhost:8844/media/uploads/2023/07/03/node_params_a0330ed0-5d73-4282-890d-f718327c26cf.mpk
2023-07-03 13:11:58,079 fedbiomed DEBUG - download of file node_params_e3b1a95e-5bf4-4db4-9682-32a05dc624d6.mpk successful, with status code 200
2023-07-03 13:11:58,081 fedbiomed INFO - Nodes that successfully reply in round 6 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:11:58,112 fedbiomed DEBUG - HTTP POST request of file /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_ff50f66b-d95f-4c80-b9e2-b9d02395e61c.mpk successful, with status code 201
2023-07-03 13:11:58,113 fedbiomed INFO - Saved aggregated params for round 6 in /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_ff50f66b-d95f-4c80-b9e2-b9d02395e61c.mpk
2023-07-03 13:11:58,113 fedbiomed INFO - Sampled nodes in round 7 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:11:58,114 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 7, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_ff50f66b-d95f-4c80-b9e2-b9d02395e61c.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_73474707-cfad-4e6a-b585-9a3520fdd776'}
2023-07-03 13:11:58,115 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:11:58,116 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 7, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_ff50f66b-d95f-4c80-b9e2-b9d02395e61c.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_d45526f2-d699-4b64-8934-90d06d77967a', 'protocol_version': '1'}
2023-07-03 13:11:58,117 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:11:58,151 fedbiomed INFO - INFO
2023-07-03 13:11:58,192 fedbiomed INFO - INFO
2023-07-03 13:11:58,198 fedbiomed INFO - INFO
2023-07-03 13:11:58,199 fedbiomed INFO - INFO
2023-07-03 13:11:58,201 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 8 | Iteration: 1/1 (100%) | Samples: 40/40
F1_SCORE: 0.867925
2023-07-03 13:11:58,205 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 8 | Iteration: 1/1 (100%) | Samples: 35/35
F1_SCORE: 0.869565
2023-07-03 13:11:58,239 fedbiomed INFO - TRAINING
Loss hinge: 0.966867
2023-07-03 13:11:58,264 fedbiomed INFO - TRAINING
Loss hinge: 0.986017
2023-07-03 13:11:58,341 fedbiomed INFO - TRAINING
Round 8 | Iteration: 3/5 (60%) | Samples: 314/640
Loss hinge: 2.760947
2023-07-03 13:11:58,349 fedbiomed INFO - TRAINING
Round 8 | Iteration: 3/5 (60%) | Samples: 351/640
Loss hinge: 3.215534
2023-07-03 13:11:58,404 fedbiomed INFO - TRAINING
Round 8 | Iteration: 4/5 (80%) | Samples: 442/640
Loss hinge: 2.841887
2023-07-03 13:11:58,419 fedbiomed INFO - TRAINING
Round 8 | Iteration: 4/5 (80%) | Samples: 479/640
Loss hinge: 2.925228
2023-07-03 13:11:58,459 fedbiomed INFO - TRAINING
Round 8 | Iteration: 5/5 (100%) | Samples: 570/640
Loss hinge: 1.613500
2023-07-03 13:11:58,461 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.666667
2023-07-03 13:11:58,469 fedbiomed INFO - TRAINING
Round 8 | Iteration: 5/5 (100%) | Samples: 607/640
Loss hinge: 1.259462
2023-07-03 13:11:58,470 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.837209
2023-07-03 13:11:58,486 fedbiomed INFO - INFO
2023-07-03 13:11:58,497 fedbiomed INFO - INFO
2023-07-03 13:12:08,137 fedbiomed INFO - Downloading model params after training on node_8641a287-262f-40cb-a01d-0b17f5c76e2e - from http://localhost:8844/media/uploads/2023/07/03/node_params_dea4b03c-c2bd-440b-9c50-bc8e0ebedd99.mpk
2023-07-03 13:12:08,145 fedbiomed DEBUG - download of file node_params_8a4dcb11-f6c5-4492-ac8f-e2246f3cb971.mpk successful, with status code 200
2023-07-03 13:12:08,147 fedbiomed INFO - Downloading model params after training on node_1c6bdcb7-99e7-4278-95c9-98caeda6971b - from http://localhost:8844/media/uploads/2023/07/03/node_params_fc32ffcd-2ab3-452b-a6fd-bb8abb558737.mpk
2023-07-03 13:12:08,153 fedbiomed DEBUG - download of file node_params_655c3559-2d88-447a-94d7-f56020623245.mpk successful, with status code 200
2023-07-03 13:12:08,155 fedbiomed INFO - Nodes that successfully reply in round 7 ['node_8641a287-262f-40cb-a01d-0b17f5c76e2e', 'node_1c6bdcb7-99e7-4278-95c9-98caeda6971b']
2023-07-03 13:12:08,178 fedbiomed DEBUG - HTTP POST request of file /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_2ed84242-6722-45ef-b979-3e0453616abe.mpk successful, with status code 201
2023-07-03 13:12:08,179 fedbiomed INFO - Saved aggregated params for round 7 in /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_2ed84242-6722-45ef-b979-3e0453616abe.mpk
2023-07-03 13:12:08,179 fedbiomed INFO - Sampled nodes in round 8 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:12:08,180 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 8, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_2ed84242-6722-45ef-b979-3e0453616abe.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_73474707-cfad-4e6a-b585-9a3520fdd776'}
2023-07-03 13:12:08,180 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:12:08,181 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 8, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_2ed84242-6722-45ef-b979-3e0453616abe.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_d45526f2-d699-4b64-8934-90d06d77967a', 'protocol_version': '1'}
2023-07-03 13:12:08,182 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:12:08,221 fedbiomed INFO - INFO
2023-07-03 13:12:08,224 fedbiomed INFO - INFO
2023-07-03 13:12:08,264 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 9 | Iteration: 1/1 (100%) | Samples: 40/40
F1_SCORE: 0.727273
2023-07-03 13:12:08,266 fedbiomed INFO - INFO
2023-07-03 13:12:08,268 fedbiomed INFO - INFO
2023-07-03 13:12:08,270 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 9 | Iteration: 1/1 (100%) | Samples: 35/35
F1_SCORE: 0.850000
2023-07-03 13:12:08,307 fedbiomed INFO - TRAINING
Round 9 | Iteration: 1/5 (20%) | Samples: 128/640
Loss hinge: 0.944156
2023-07-03 13:12:08,347 fedbiomed INFO - TRAINING
Loss hinge: 0.995382
2023-07-03 13:12:08,430 fedbiomed INFO - TRAINING
Round 9 | Iteration: 3/5 (60%) | Samples: 351/640
Loss hinge: 1.384562
2023-07-03 13:12:08,446 fedbiomed INFO - TRAINING
Round 9 | Iteration: 3/5 (60%) | Samples: 314/640
Loss hinge: 1.229974
2023-07-03 13:12:08,487 fedbiomed INFO - TRAINING
Round 9 | Iteration: 4/5 (80%) | Samples: 479/640
Loss hinge: 1.127323
2023-07-03 13:12:08,498 fedbiomed INFO - TRAINING
Round 9 | Iteration: 4/5 (80%) | Samples: 442/640
Loss hinge: 1.205052
2023-07-03 13:12:08,543 fedbiomed INFO - TRAINING
Round 9 | Iteration: 5/5 (100%) | Samples: 607/640
Loss hinge: 0.900732
2023-07-03 13:12:08,546 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.666667
2023-07-03 13:12:08,563 fedbiomed INFO - TRAINING
Round 9 | Iteration: 5/5 (100%) | Samples: 570/640
Loss hinge: 1.179523
2023-07-03 13:12:08,568 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.777778
2023-07-03 13:12:08,582 fedbiomed INFO - INFO
2023-07-03 13:12:08,588 fedbiomed INFO - INFO
2023-07-03 13:12:18,201 fedbiomed INFO - Downloading model params after training on node_1c6bdcb7-99e7-4278-95c9-98caeda6971b - from http://localhost:8844/media/uploads/2023/07/03/node_params_b6c491dc-c946-4799-aaec-584e33a040fa.mpk
2023-07-03 13:12:18,206 fedbiomed DEBUG - download of file node_params_fc646d1c-eaf2-41dc-b155-3413e8ada296.mpk successful, with status code 200
2023-07-03 13:12:18,207 fedbiomed INFO - Downloading model params after training on node_8641a287-262f-40cb-a01d-0b17f5c76e2e - from http://localhost:8844/media/uploads/2023/07/03/node_params_b4447156-3406-4cba-8842-bfb2fd27208b.mpk
2023-07-03 13:12:18,213 fedbiomed DEBUG - download of file node_params_23e098aa-aa5a-41c0-8dd6-d72f9a2cdeb2.mpk successful, with status code 200
2023-07-03 13:12:18,215 fedbiomed INFO - Nodes that successfully reply in round 8 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:12:18,239 fedbiomed DEBUG - HTTP POST request of file /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_5f0677f1-a85a-4bc3-b213-c607a2030e8d.mpk successful, with status code 201
2023-07-03 13:12:18,240 fedbiomed INFO - Saved aggregated params for round 8 in /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_5f0677f1-a85a-4bc3-b213-c607a2030e8d.mpk
2023-07-03 13:12:18,241 fedbiomed INFO - Sampled nodes in round 9 ['node_1c6bdcb7-99e7-4278-95c9-98caeda6971b', 'node_8641a287-262f-40cb-a01d-0b17f5c76e2e']
2023-07-03 13:12:18,242 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 9, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_5f0677f1-a85a-4bc3-b213-c607a2030e8d.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_73474707-cfad-4e6a-b585-9a3520fdd776'}
2023-07-03 13:12:18,243 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:12:18,246 fedbiomed INFO - Sending request
Request: : Perform training with the arguments: {'researcher_id': 'researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e', 'job_id': '598d23e9-d91e-4526-b1b4-aa8ab8b2e30a', 'training_args': {'num_updates': 5, 'batch_size': 128, 'dry_run': False, 'optimizer_args': {}, 'epochs': None, 'batch_maxnum': None, 'test_ratio': 0.1, 'test_on_local_updates': True, 'test_on_global_updates': True, 'test_metric': 'F1_SCORE', 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'max_iter': 1000, 'tol': 0.1, 'n_features': 18, 'n_classes': 2, 'loss': 'hinge', 'verbose': 1}, 'round': 9, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_b511f38a-c219-4bcd-9a43-27bcd5a25797.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_5f0677f1-a85a-4bc3-b213-c607a2030e8d.mpk', 'training_plan_class': 'SkLearnClassifierTrainingPlan', 'dataset_id': 'dataset_d45526f2-d699-4b64-8934-90d06d77967a', 'protocol_version': '1'}
2023-07-03 13:12:18,247 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:12:18,281 fedbiomed INFO - INFO
2023-07-03 13:12:18,282 fedbiomed INFO - INFO
2023-07-03 13:12:18,323 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 10 | Iteration: 1/1 (100%) | Samples: 40/40
F1_SCORE: 0.863636
2023-07-03 13:12:18,326 fedbiomed INFO - INFO
2023-07-03 13:12:18,357 fedbiomed INFO - INFO
2023-07-03 13:12:18,359 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 10 | Iteration: 1/1 (100%) | Samples: 35/35
F1_SCORE: 0.620690
2023-07-03 13:12:18,363 fedbiomed INFO - TRAINING
Round 10 | Iteration: 1/5 (20%) | Samples: 128/640
Loss hinge: 1.196435
2023-07-03 13:12:18,395 fedbiomed INFO - TRAINING
Loss hinge: 0.714835
2023-07-03 13:12:18,466 fedbiomed INFO - TRAINING
Round 10 | Iteration: 3/5 (60%) | Samples: 314/640
Loss hinge: 1.649812
2023-07-03 13:12:18,467 fedbiomed INFO - TRAINING
Round 10 | Iteration: 3/5 (60%) | Samples: 351/640
Loss hinge: 4.314792
2023-07-03 13:12:18,512 fedbiomed INFO - TRAINING
Round 10 | Iteration: 4/5 (80%) | Samples: 442/640
Loss hinge: 3.994241
2023-07-03 13:12:18,516 fedbiomed INFO - TRAINING
Round 10 | Iteration: 4/5 (80%) | Samples: 479/640
Loss hinge: 1.290517
2023-07-03 13:12:18,560 fedbiomed INFO - TRAINING
Round 10 | Iteration: 5/5 (100%) | Samples: 570/640
Loss hinge: 1.708250
2023-07-03 13:12:18,563 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.750000
2023-07-03 13:12:18,572 fedbiomed INFO - TRAINING
Round 10 | Iteration: 5/5 (100%) | Samples: 607/640
Loss hinge: 1.282847
2023-07-03 13:12:18,575 fedbiomed INFO - VALIDATION ON LOCAL UPDATES
F1_SCORE: 0.851064
2023-07-03 13:12:18,595 fedbiomed INFO - INFO
2023-07-03 13:12:18,604 fedbiomed INFO - INFO
2023-07-03 13:12:28,259 fedbiomed INFO - Downloading model params after training on node_8641a287-262f-40cb-a01d-0b17f5c76e2e - from http://localhost:8844/media/uploads/2023/07/03/node_params_deca3fdb-b149-4302-bd2b-d16ddbbadab8.mpk
2023-07-03 13:12:28,263 fedbiomed DEBUG - download of file node_params_1dd53dca-818d-400e-9975-6ffe7eb6170f.mpk successful, with status code 200
2023-07-03 13:12:28,264 fedbiomed INFO - Downloading model params after training on node_1c6bdcb7-99e7-4278-95c9-98caeda6971b - from http://localhost:8844/media/uploads/2023/07/03/node_params_212cd78e-6078-4b5d-a21e-eef8154f0a37.mpk
2023-07-03 13:12:28,269 fedbiomed DEBUG - download of file node_params_2f5c982f-cc6e-4fc5-94e0-77f159bf3aa5.mpk successful, with status code 200
2023-07-03 13:12:28,271 fedbiomed INFO - Nodes that successfully reply in round 9 ['node_8641a287-262f-40cb-a01d-0b17f5c76e2e', 'node_1c6bdcb7-99e7-4278-95c9-98caeda6971b']
2023-07-03 13:12:28,291 fedbiomed DEBUG - HTTP POST request of file /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_112c956e-b7d7-4fb6-9238-d450adb9770f.mpk successful, with status code 201
2023-07-03 13:12:28,292 fedbiomed INFO - Saved aggregated params for round 9 in /user/linnocen/home/fedbiomed/var/experiments/Experiment_0001/aggregated_params_112c956e-b7d7-4fb6-9238-d450adb9770f.mpk
2023-07-03 13:12:28,293 fedbiomed INFO - Sending request
Request: :Perform final validation on aggregated parameters
2023-07-03 13:12:28,294 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:12:28,295 fedbiomed INFO - Sending request
2023-07-03 13:12:28,296 fedbiomed DEBUG - researcher_5d3b393d-e248-4e3f-a028-b87fe5fbbe6e
2023-07-03 13:12:28,326 fedbiomed INFO - INFO
2023-07-03 13:12:28,328 fedbiomed INFO - INFO
2023-07-03 13:12:28,358 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 11 | Iteration: 1/1 (100%) | Samples: 40/40
F1_SCORE: 0.812500
2023-07-03 13:12:28,361 fedbiomed INFO - INFO
2023-07-03 13:12:28,362 fedbiomed INFO - INFO
2023-07-03 13:12:28,398 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
Round 11 | Iteration: 1/1 (100%) | Samples: 35/35
F1_SCORE: 0.750000
10
