Brain Segmentation#
This tutorial will show how to use Fed-BioMed to perform image segmentation on 3D medical MRI images of brains, using the publicly available IXI dataset. It uses a 3D U-Net model for the segmentation, trained on data from 3 separate centers.
Here we display a very complex case, using advanced Fed-BioMed functionalities such as:
  • exploring the datasets in the federation
  • loading a MedicalImageDataset
  • monitoring training loss with Tensorboard
Parts of this tutorial are based on TorchIO’s tutorial.
Table of Contents#
  • Task 1: Discovering datasets
  • Task 2: MedicalFolderDataset class
  • Task 3: Federated feature analytics
  • Task 4: Train a UNet model
  • Task 5: Validation on a local holdout set
%load_ext tensorboard
import os
import tabulate
from pprint import pprint
import matplotlib.pyplot as plt
import numpy as np
import torch
import torch.nn as nn
import torch.nn.functional as F
from torch.optim import AdamW, SGD
from torch.utils.data import DataLoader
from monai.networks.nets import UNet
from monai.losses.dice import DiceLoss
from monai.transforms import (Compose, NormalizeIntensity, AddChannel, Resize, AsDiscrete)
from fedbiomed.common.training_plans import BaseTrainingPlan, TorchTrainingPlan
from fedbiomed.common.logger import logger
from fedbiomed.common.data import DataManager, MedicalFolderDataset
from fedbiomed.researcher.requests import Requests
from fedbiomed.researcher.aggregators import Aggregator, FedAverage
from fedbiomed.researcher.environ import environ
from fedbiomed.common.training_args import TrainingArgs
from fedbiomed.researcher.experiment import Experiment
2023-07-03 15:11:32,411 - Selected pickle protocol: '4'
%matplotlib inline
Task 1: Discovering datasets #
Let’s discover which datasets are available for federated training in the network.
Try it yourself!#
Read the documentation for the Requests class to figure out which function call can be used to list all the available datasets.
req = Requests()
datasets = req.list(verbose=False)
2023-07-03 15:11:35,240 fedbiomed INFO - Messaging researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87 successfully connected to the message broker, object = <fedbiomed.common.messaging.Messaging object at 0x7ffa9c238160>
2023-07-03 15:11:35,261 fedbiomed INFO - Listing available datasets in all nodes...
pprint(datasets)
{'node_10797f2f-2524-4595-a1c6-f3c67e03add1': [{'data_type': 'medical-folder',
                                                'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503',
                                                'dataset_parameters': {'index_col': 13},
                                                'description': '',
                                                'name': 'ixi site 2',
                                                'shape': {'T1': [83, 44, 55],
                                                          'T2': [83, 44, 55],
                                                          'demographics': [69,
        13],
                                                          'label': [83, 44, 55],
                                                          'num_modalities': 3},
                                                'tags': ['ixi-jupyter-sharkovsky']},
                                               {'data_type': 'mednist',
                                                'dataset_id': 'dataset_d25841b6-022d-4fba-bfd0-a19de2fc19f8',
                                                'dataset_parameters': None,
                                                'description': 'mednist client '
                                                               '2',
                                                'name': 'MedNIST client 2',
                                                'shape': [18000, 3, 64, 64],
                                                'tags': ['mednist-jupyter-sharkovsky']},
                                               {'data_type': 'csv',
                                                'dataset_id': 'dataset_3fffa907-7569-46f0-a2b1-fa7245e42499',
                                                'description': 'heart client 2',
                                                'name': 'Heart disease client '
                                                        '2',
                                                'shape': [349, 19],
                                                'tags': ['heart-jupyter-sharkovsky']}],
 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1': [{'data_type': 'medical-folder',
                                                'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24',
                                                'description': '',
                                                'name': 'ixi site 1',
                                                          'T2': [83, 44, 55],
                                                          'demographics': [305,
        13],
                                                'dataset_id': 'dataset_650c023c-0177-469a-b70e-9a4ed6e26c44',
                                                               '1',
                                                'name': 'MedNIST client 1',
                                                'dataset_id': 'dataset_6dc88f60-68fb-4bc7-aa01-2f339ea0c08d',
                                                'description': 'heart client 1',
                                                        '1',
                                                'shape': [391, 19],
                                                'tags': ['heart-jupyter-sharkovsky']}]}
Filter results#
There are a lot of datasets available! However, most of them are from nodes that are going to collaborate with other users, not you. To identify datasets that were intended for your use, you should look at the value of the tags.
Try it yourself!#
Fill in the body of the for loop below such that the datasets_for_me variable follows these rules:
  • it has the same structure as the datasets variable
  • it has all and only the datasets whose tag contains your username
my_username = 'sharkovsky'
datasets_for_me = dict()
for node, _data in datasets.items():
    datasets_for_me[node] = list(filter( lambda dataset: any(my_username in x for x in dataset['tags']), _data))
pprint(datasets_for_me)
                                                'description': '',
                                                          'T2': [83, 44, 55],
        13],
                                                               '2',
                                                        '2',
                                                'shape': [349, 19],
                                                'description': '',
                                                          'T2': [83, 44, 55],
        13],
                                                               '1',
                                                        '1',
                                                'shape': [391, 19],
Tabulate results#
Try it yourself!#
Looking at the format of the datasets_for_me variable, produce a table with the following format using the tabulate package:
site
dataset name
sample size
node_3d7f08fa-ee13-4033-8a01-93b448b6c8be
ixi
177
tabulate_sample_sizes = list()
for node, _data in datasets_for_me.items():
    for d in _data:
        if d['data_type'] == 'medical-folder':
            tabulate_sample_sizes.append([node, d['name'], d['shape']['demographics'][0]])
        else:
            tabulate_sample_sizes.append([node, d['name'], d['shape'][0]])
print(tabulate.tabulate(tabulate_sample_sizes, headers=('site', 'dataset name', 'sample size')))
site                                       dataset name              sample size
node_10797f2f-2524-4595-a1c6-f3c67e03add1  ixi site 2                         69
node_10797f2f-2524-4595-a1c6-f3c67e03add1  MedNIST client 2                18000
node_10797f2f-2524-4595-a1c6-f3c67e03add1  Heart disease client 2            349
node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1  ixi site 1                        305
node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1  MedNIST client 1                18000
node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1  Heart disease client 1            391
Task 2: MedicalFolderDataset #
To help you get familiar with this loading medical imaging data in Fed-BioMed, we will practice on a smaller dataset that we assume is available to you locally as a researcher. This is often the case in FL settings where the reseaercher has a small holdout dataset for local validation.
We will use Fed-BioMed’s built-in class for image segmentation tasks: MedicalFolderDataset. This class supports several medical imaging modalities (think all the different types of MRI, CT, PET, etc..). It is optimized for segmentation tasks but can be applied to other tasks (e.g. classification, regression, …). This class supports loading a set of patient demographics data in csv format, in addition to the imaging data.
The inputs to the __init__ function are:
  • root: the filesystem path where the root of the dataset is located
  • data_modalities: the names of the modalities of interest for the input data
  • target_modalities: the names of the modalities of interest for the data to be predicted
  • transform: optional transformations to be performed on the input images
  • target_transform: optional transformations to be performed on the target data
  • demographics_transform: optional transformations to be performed on the demographics (csv) data
Let’s create the dataset:
dataset = MedicalFolderDataset(
    root='/datasets/ixi/holdout',
    data_modalities=['T1', 'T2'],
    target_modalities='label',
    transform=None,
    target_transform=None,
    demographics_transform=None)
Try it yourself!#
You can find out the total number of images with the len function, and access images individually with the [idx] operator, where idx is an integer index.
Note: dataset[0] will return a tuple corresponding to index 0. The tuple will be in the form (inputs, targets).
What is the format of inputs and targets? How do you access a single image? What data type is it, what is its format and shape? How do you access the corresponding binary mask?
(inputs, targets) = dataset[0]
image_modalities, demographics = inputs
img_t1 = image_modalities['T1']
img_t2 = image_modalities['T2']
segm_mask = targets['label']
Try it yourself!#
Plot two images. On the left, the raw input image. On the right, again the raw input image as background but overlayed with the ground truth segmentation. Take some time to familiriaze yourself with the approach for making the overlay plot, and all the plotting arguments that we use.
fig, ax = plt.subplots(1,2, figsize=(6,8))
slice_to_plot = 24
(image_modalities, demographics), target = dataset[42]
img = image_modalities['T1'][..., slice_to_plot]
ax[0].imshow(img, cmap='bone')
ax[0].invert_yaxis()
ax[1].imshow(img, cmap='bone')
label = target['label'][..., slice_to_plot]
plot = ax[1].imshow(np.ma.masked_where(
                        label < 0.5,
                        label), cmap='winter', alpha=0.5, interpolation='none', vmin=0., vmax=1.)
ax[1].invert_yaxis()
fig.suptitle('Input slice with ground truth overlay')
fig.colorbar(plot, ax=ax, location='bottom')
<matplotlib.colorbar.Colorbar at 0x7ff94c9513a0>
../_images/b86387feadbecf41afc12a8ad3927eacd1f303518412858b7d868bca5e62290f.png
Task 3: Federated feature analytics #
We want to obtain some basic information about the distribution of values of our features (i.e. the pixels in the MRI images). Our ultimate goal is to obtain an histogram of the counts of pixel values, but this will require a few steps, showcasing how flexible and interactive Fed-BioMed can be.
Hacking ahead!
The following code will slightly bend the current intended usage of some Fed-BioMed classes. You will be working on the alpha version of a functionality which we are actively working on right now.
Federated Min and Max: TrainingPlan#
We need to do some preliminary work in order to compute a federated histogram. One information that we need is the minimum and maximum pixel values over the whole federation, in order to compute a stable set of histogram bins across all the nodes in the federation. (Think about what would happen if we let each node compute their own histogram bins independently).
Implementation details#
We are going to “hack” a TorchTrainingPlan in order to compute a minimum and a maximum instead of training a model.
To understand what is going on exactly, you need the information below on some details about Fed-BioMed. If you are not interested, you can skip directly to the description of what you need to do to complete the code below.
The TrainingPlan should implement at least four important functions:
  • init_model: create the model (nn.Module) to be trained
  • init_optimizer: create the optimizer
  • training_data: to instantiate the dataset on the node (with customizations made by the researcher)
  • training_routine or training_step: the actual training code. The latter is a simple shorthand if you only need to customize the training on a single batch, without worrying about managing the data loader, iterations, etc..
The diagram below simplifies the main steps that constitute a run of a federated experiment in Fed-BioMed:
exp.run
Define data loading and transformations#
In what follows, we provide a suggestion for defining the data loading. The training_data function will use MedicalFolderDataset.
Additionally, we can define image transformations for the input images and the labels.
Finally, we define a transformation for the demographics data. Note that this is a required step to ensure that the demographics csv data is transformed into a torch Tensor usable by the training routine.
Our strategy: training_routine#
We will implement a training_routine that does not really perform any training. Instead, it does one full pass over the whole dataset to find the maximum and the minimum.
Our strategy: the MinMaxTracker model#
We will create a model that inherits from nn.Module but is not a neural network. Instead, it will simply contain a dictionary to store the minimum and maximum pixel values.
The init_model function of the TrainingPlan simply needs to return an instance of MinMaxTracker.
The init_optimizer function will return a dummy torch optimizer, since there is no actual optimization happening during our training.
The implementation details of how a model is handled can be a bit confusing at first. Here is a simplified diagram detailing the interactions between the main classes during a federated training round.
diagram
Try it yourself!#
Fill in the code below in the MinMaxTracker and training_routine.
class FedMinMaxTrainingPlan(TorchTrainingPlan):
    class MinMaxTracker(nn.Module):
        def __init__(self):
            super().__init__()
            self.min_max = {'min': torch.Tensor([np.infty]),
                            'max': torch.Tensor([-np.infty])}
        def state_dict(self):
            return self.min_max
        def load_state_dict(self, params, strict=False):
            self.min_max = {'min': params['min'], 'max': params['max']}
            class MockMissingKeys:
                def __init__(self):
                    self.missing_keys = []
                    self.unexpected_keys = []
            return MockMissingKeys()
        def named_parameters(self):
            return self.min_max.items()
    def init_model(self, model_arguments):
        return FedMinMaxTrainingPlan.MinMaxTracker()
    def training_step(self, *args, **kwargs):
        pass
    def init_optimizer(self, optimizer_arguments):
        return SGD([torch.Tensor([0])], lr=0.)
    def init_dependencies(self):
        deps = [
            "from monai.transforms import (Compose, NormalizeIntensity, AddChannel, Resize, AsDiscrete)",
            "from fedbiomed.common.data import MedicalFolderDataset",
            'import numpy as np',
            'from torch.optim import SGD'
        return deps
    @staticmethod
    def demographics_transform(demographics: dict):
        return {}
    def training_data(self,  batch_size = 4):
    # The training_data creates the Dataloader to be used for training in the general class Torchnn of fedbiomed
        common_shape = (44, 44, 56)
        training_transform = Compose([AddChannel(), Resize(common_shape)])
        target_transform = Compose([AddChannel(), Resize(common_shape), AsDiscrete(to_onehot=2)])
            root=self.dataset_path,
            data_modalities='T1',
            transform=training_transform,
            target_transform=target_transform,
            demographics_transform=FedMinMaxTrainingPlan.demographics_transform)
        train_kwargs = {'batch_size': batch_size, 'shuffle': False}
        return DataManager(dataset, **train_kwargs)
    def training_routine(self,
                         history_monitor = None,
                         node_args = None):
        count = 0
        prev_min = self._model.get_weights()['min']
        prev_max = self._model.get_weights()['max']
        for data, target in self.training_data_loader:
            images, demographics = data
            image = images['T1']
            count += 1
            thismin = image.min()
            if thismin < prev_min:
                prev_min = thismin
            thismax = image.max()
            if thismax > prev_max:
                prev_max = thismax
        self._model.set_weights({'min': prev_min,
                                  'max': prev_max})
        return count
Federated Min and Max: Aggregator#
The Aggregator must implement an aggregate function that returns a dictionary of model parameters.
Try it yourself!#
Fill in the code for the aggregate function.
The inputs are:
  • model_params: a dictionary {node_id: model_params_after_training}, where model_params_after_training is the state_dict of the MinMaxTracker model after local training on the node.
  • weights: a dictionary {node_id: weight} where the weight is a float between 0 and 1 computed as a proportion of the number of samples in the node to the total number of samples in the federation.
The output should be a dictionary with the same format as the state_dict of the MinMaxTracker model, i.e. it should be a dictionary:
  'min': torch.Tensor([aggregated_minimum]),
  'max': torch.Tensor([aggregated_maximum])
class MinMaxAggregator(Aggregator):
    def __init__(self):
        super(MinMaxAggregator, self).__init__()
        self.aggregator_name = "MinMaxAggregator"
    def aggregate(self, model_params: dict, weights: dict, *args, **kwargs):
        all_minimums = all_maximums = list()
        for node_id, min_max in model_params.items():
            all_minimums.append(min_max['min'])
            all_maximums.append(min_max['max'])
        return {'min': min(all_minimums), 'max': max(all_maximums)}
Define the experiment#
TAGS: Replace %%%% in the tags with your username
tags =  ['ixi-jupyter-sharkovsky']
exp = Experiment(tags=tags,
                 model_args={},
                 training_plan_class=FedMinMaxTrainingPlan,
                 training_args={},
                 round_limit=1,  # just a single round, with a pass over the whole dataset
                 aggregator=MinMaxAggregator(),
                 tensorboard=False,
                 save_breakpoints=False
2023-07-03 15:24:37,093 fedbiomed INFO - Searching dataset with data tags: ['ixi-jupyter-sharkovsky'] for all nodes
2023-07-03 15:24:47,106 fedbiomed INFO - Node selected for training -> node_10797f2f-2524-4595-a1c6-f3c67e03add1
2023-07-03 15:24:47,107 fedbiomed INFO - Node selected for training -> node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1
2023-07-03 15:24:47,108 fedbiomed INFO - Checking data quality of federated datasets...
Secure RNG turned off. This is perfectly fine for experimentation as it allows for much faster training performance, but remember to turn it on and retrain one last time before production with ``secure_mode`` turned on.
2023-07-03 15:24:47,109 fedbiomed DEBUG - using native torch optimizer
2023-07-03 15:24:47,110 fedbiomed DEBUG - Model file has been saved: /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0033/my_model_9fa23f7d-e9a4-4505-957b-5e27cac51a77.py
2023-07-03 15:24:47,122 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0033/my_model_9fa23f7d-e9a4-4505-957b-5e27cac51a77.py successful, with status code 201
2023-07-03 15:24:47,134 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0033/aggregated_params_2ecfce57-76c6-4d35-aa13-fefb9d81fb83.mpk successful, with status code 201
exp.run_once()
2023-07-03 15:24:47,139 fedbiomed INFO - Sampled nodes in round 0 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:24:47,139 fedbiomed INFO - Sending request
					 To: node_10797f2f-2524-4595-a1c6-f3c67e03add1
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '7de014e1-0fac-4346-81f6-b2901f7d71c8', 'training_args': {'optimizer_args': {}, 'batch_size': 1, 'epochs': None, 'num_updates': None, 'dry_run': False, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {}, 'round': 0, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_9fa23f7d-e9a4-4505-957b-5e27cac51a77.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_2ecfce57-76c6-4d35-aa13-fefb9d81fb83.mpk', 'training_plan_class': 'FedMinMaxTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:24:47,140 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:24:47,140 fedbiomed INFO - Sending request
					 To: node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '7de014e1-0fac-4346-81f6-b2901f7d71c8', 'training_args': {'optimizer_args': {}, 'batch_size': 1, 'epochs': None, 'num_updates': None, 'dry_run': False, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {}, 'round': 0, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_9fa23f7d-e9a4-4505-957b-5e27cac51a77.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_2ecfce57-76c6-4d35-aa13-fefb9d81fb83.mpk', 'training_plan_class': 'FedMinMaxTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:24:47,141 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:25:02,153 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_be11c61b-3591-41b3-a048-1ebb38235ad3.mpk
2023-07-03 15:25:02,157 fedbiomed DEBUG - download of file node_params_07404e40-61c4-4e73-9db7-ce5aea25609a.mpk successful, with status code 200
2023-07-03 15:25:02,158 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_2b570b81-000f-476d-a829-640f02d5a575.mpk
2023-07-03 15:25:02,161 fedbiomed DEBUG - download of file node_params_d171010e-01eb-4428-9392-0723cdf5e208.mpk successful, with status code 200
2023-07-03 15:25:02,163 fedbiomed INFO - Nodes that successfully reply in round 0 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:25:02,179 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0033/aggregated_params_578f21f9-e589-4eef-b756-ccb9cc54cb7a.mpk successful, with status code 201
2023-07-03 15:25:02,179 fedbiomed INFO - Saved aggregated params for round 0 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0033/aggregated_params_578f21f9-e589-4eef-b756-ccb9cc54cb7a.mpk
1
Try it yourself!#
How can you access the minimum and maximum over the whole federation, after aggregation?
Hint: the experiment holds a copy of the training plan, which contains the model.
fed_min = exp.training_plan().model().state_dict()['min']
fed_max = exp.training_plan().model().state_dict()['max']
Federated Histogram: TrainingPlan#
We want to compute the average histogram of pixel values, where the average is computed over the different images.
We will implement a training_routine that does not really perform any training. Instead, it does one full pass over the whole dataset to compute the average histogram per image.
Our strategy: the FedHistogram model#
We will create a model that inherits from nn.Module but is not a neural network. Instead, it will simply contain a dictionary to store the histogram, minimum and maximum pixel values (computed before) and the number of bins. Note that the real “parameter” of this model, i.e. the one that will be updated, is the histogram data. All the rest are static values that will not be updated nor aggregated. We will use model_arguments and training_arguments to pass these values.
The init_model function of the TrainingPlan simply needs to return an instance of FedHistogram.
Our strategy: training_data#
Try it yourself!#
Fill in the code for FedHistogram, init_model and training_routine.
class FedHistogramTrainingPlan(TorchTrainingPlan):
    class FedHistogram(nn.Module):
        def __init__(self, bin_min=0., bin_max=1e+5, nbins=10):
            super().__init__()
            self.hist_data = {'hist': torch.Tensor([np.nan]),
                              'bin_min': torch.Tensor([bin_min]),
                              'bin_max': torch.Tensor([bin_max]),
                              'nbins': torch.Tensor([nbins])}
            return self.hist_data
            self.hist_data = params
                def __init__(self):
            return self.hist_data.items()
    def init_model(self, model_args):
        return FedHistogramTrainingPlan.FedHistogram(
            bin_min = model_args['bin_min'],
            bin_max = model_args['bin_max'],
            nbins = model_args['nbins']
        pass
        deps = [
        return deps
    @staticmethod
        return {}
            demographics_transform=FedHistogramTrainingPlan.demographics_transform)
                         node_args = None):
        hist_metadata = self._model.get_weights()
        nbins = int(hist_metadata['nbins'].numpy().tolist()[0])
        bin_min = hist_metadata['bin_min'].numpy().tolist()[0]
        bin_max = hist_metadata['bin_max'].numpy().tolist()[0]
        count = 0
        hist = hist_metadata['hist']
            count += 1
            if count==1 :
                hist, _ = np.histogram(image.flatten().numpy(),
                                       bins=nbins,
                                       range=(bin_min, bin_max))
            else:
                tmp_hist_, _ = np.histogram(image.flatten().numpy(),
                                       bins=nbins,
                hist += tmp_hist_
        self._model.set_weights({'hist': hist / np.array([float(count)]),
                                 'nbins': hist_metadata['nbins'],
                                 'bin_min': hist_metadata['bin_min'],
                                 'bin_max': hist_metadata['bin_max']})
        return count
Federated Histogram: Aggregator#
The Aggregator must implement an aggregate function that returns a dictionary of model parameters. In this case it is important to compute a weighted average of the histograms returned from each node (think about why a non-weighted mean is biased). For this, you can use the weights argument of the aggregate function.
Try it yourself!#
Reminder, the inputs to aggregate are:
class HistAggregator(Aggregator):
    def __init__(self):
        super(HistAggregator, self).__init__()
        self.aggregator_name = "HistAggregator"
    def aggregate(self, model_params: list, weights: list, *args, **kwargs):
        hist = None
        for node_id, hist_data in model_params.items():
            if hist is None:
                hist = hist_data['hist']*weights[node_id]
            else:
                hist += hist_data['hist']*weights[node_id]
        return {'hist': hist,
                'nbins': hist_data['nbins'],
                'bin_min': hist_data['bin_min'],
                'bin_max': hist_data['bin_max']}
This time we will use model_args to pass to the node the federated minimum and maximum (computed before) as well as the number of bins.
Seralization: Arguments are sent over the network to the nodes: this requires that they can be serialized.
Our computed values for the federated minimum and maximum are not serializable because they are torch.Tensor: you need to find a way to convert them to regular python float.
model_args = {
    'bin_min': fed_min.detach().numpy().tolist(),
    'bin_max': fed_max.detach().numpy().tolist(),
    'nbins': 100
                 model_args=model_args,
                 training_plan_class=FedHistogramTrainingPlan,
                 training_args={},
                 round_limit=1,
                 aggregator=HistAggregator(),
                 tensorboard=False,
2023-07-03 15:25:08,221 fedbiomed INFO - Searching dataset with data tags: ['ixi-jupyter-sharkovsky'] for all nodes
2023-07-03 15:25:18,234 fedbiomed INFO - Node selected for training -> node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1
2023-07-03 15:25:18,235 fedbiomed INFO - Node selected for training -> node_10797f2f-2524-4595-a1c6-f3c67e03add1
2023-07-03 15:25:18,238 fedbiomed INFO - Checking data quality of federated datasets...
2023-07-03 15:25:18,239 fedbiomed DEBUG - using native torch optimizer
2023-07-03 15:25:18,240 fedbiomed DEBUG - Model file has been saved: /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0034/my_model_70d7233b-531d-4d27-b244-706d6027db39.py
2023-07-03 15:25:18,250 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0034/my_model_70d7233b-531d-4d27-b244-706d6027db39.py successful, with status code 201
2023-07-03 15:25:18,259 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0034/aggregated_params_f9a3f411-0759-4ab9-b40a-e32857417ce2.mpk successful, with status code 201
exp.run_once()
2023-07-03 15:25:18,264 fedbiomed INFO - Sampled nodes in round 0 ['node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1', 'node_10797f2f-2524-4595-a1c6-f3c67e03add1']
2023-07-03 15:25:18,264 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'f055eee4-41aa-4562-aad1-44f0e78d0a7c', 'training_args': {'optimizer_args': {}, 'batch_size': 1, 'epochs': None, 'num_updates': None, 'dry_run': False, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'bin_min': -4.25, 'bin_max': 10791.6669921875, 'nbins': 100}, 'round': 0, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_70d7233b-531d-4d27-b244-706d6027db39.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_f9a3f411-0759-4ab9-b40a-e32857417ce2.mpk', 'training_plan_class': 'FedHistogramTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24'}
2023-07-03 15:25:18,264 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:25:18,265 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': 'f055eee4-41aa-4562-aad1-44f0e78d0a7c', 'training_args': {'optimizer_args': {}, 'batch_size': 1, 'epochs': None, 'num_updates': None, 'dry_run': False, 'batch_maxnum': None, 'test_ratio': 0.0, 'test_on_local_updates': False, 'test_on_global_updates': False, 'test_metric': None, 'test_metric_args': {}, 'log_interval': 10, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'bin_min': -4.25, 'bin_max': 10791.6669921875, 'nbins': 100}, 'round': 0, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_70d7233b-531d-4d27-b244-706d6027db39.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_f9a3f411-0759-4ab9-b40a-e32857417ce2.mpk', 'training_plan_class': 'FedHistogramTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503', 'protocol_version': '1'}
2023-07-03 15:25:18,265 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:25:33,282 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_d2036983-9321-46a1-a9b1-07e0142a166c.mpk
2023-07-03 15:25:33,286 fedbiomed DEBUG - download of file node_params_9bda9355-2b96-4a4e-af7c-7658158bda80.mpk successful, with status code 200
2023-07-03 15:25:33,287 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_6d6be718-3bb1-49bf-80e1-0ecf50dc4dd9.mpk
2023-07-03 15:25:33,290 fedbiomed DEBUG - download of file node_params_d5437393-40a2-46b1-9395-57811dc6ad43.mpk successful, with status code 200
2023-07-03 15:25:33,291 fedbiomed INFO - Nodes that successfully reply in round 0 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:25:33,302 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0034/aggregated_params_9cfb69df-b812-42d5-85f0-b1963402e0d9.mpk successful, with status code 201
2023-07-03 15:25:33,302 fedbiomed INFO - Saved aggregated params for round 0 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0034/aggregated_params_9cfb69df-b812-42d5-85f0-b1963402e0d9.mpk
1
Sanity check#
It is always good to check the outputs of our calculations. What should the sum of all values in the aggregated histogram be equal to?
sum_of_pixel_counts = exp.training_plan().model().state_dict()['hist'].sum()
expected_value = 44*44*56
print(f"The sum of average pixel counts {sum_of_pixel_counts} "
      f"should be equal to the total image size {expected_value}")
The sum of average pixel counts 108415.99999999999 should be equal to the total image size 108416
Plot the histograms#
The aggregated histogram#
Try it yourself#
  1. Using the values from model_args, obtain the size (the width) of each bin
  2. Compute the array of bin edges
  3. plot the histogram using the ax.bar function
fig, ax = plt.subplots(figsize=(12,6))
width_histogram_bin = (model_args['bin_max'] - model_args['bin_min'])/model_args['nbins']
bin_edges = np.arange(start=model_args['bin_min'],
                      stop=model_args['bin_max'],
                      step=width_histogram_bin)
ax.bar(bin_edges,
       exp.training_plan().model().state_dict()['hist'],
       width=0.99*width_histogram_bin)
_ = ax.set_ylabel('Average count per image')
_ = ax.set_xlabel('Pixel value')
_ = ax.set_title('Aggregated histogram')
../_images/a62420fddc0393aeb9e9df82bc99be5ded99ff52f7d4aa5595ded26687cbed5b.png
The node-wise histograms#
Try it yourself#
You can access the models’ state_dicts (after training) through the exp.training_replies() function. The output is a dictionary of the format {round: node_replies}, where node_replies is a list of replies. Each reply is a dictionary, where node_id and params are the most important keys for this task.
fig, ax = plt.subplots(2,1,figsize=(12,6))
width_histogram_bar = (model_args['bin_max'] - model_args['bin_min'])/model_args['nbins']
                     step=width_histogram_bar)
for i in range(2):
    hist_data = exp.training_replies()[0][i]['params']['hist']
    node_id = exp.training_replies()[0][i]['node_id']
    ax[i].bar(bin_edges, hist_data, width=0.99*width_histogram_bar)
    _ = ax[i].set_ylabel('Average count per image')
    _ = ax[i].set_title(f'Histogram for {node_id}')
_ = ax[1].set_xlabel('Pixel value')
fig.tight_layout()
../_images/6fdce8bb1b5937e96076de6d9712cf62870f3556d7a80d494d88cf5517b60318.png
Try it yourself!#
What happens if we normalize the images while loading them? Add NormalizeIntensity() as an additional transform for the loaded images in the TrainingPlan, and check how the histogram changes shape.
Task 4: Training a UNet model for the brain segmentation task #
Create a Training Plan#
We create a training plan that incorporates the UNet model.
Define the neural network model#
We recommend using MONAI’s UNet implementation.
We define the model in the __init__ and forward functions of the training plan.
Define the loss function#
Loss function is computed based on the Dice Loss.
Carole H Sudre, Wenqi Li, Tom Vercauteren, Sebastien Ourselin, and M Jorge Cardoso. Generalised dice overlap as a deep learning loss function for highly unbalanced segmentations. In Deep learning in medical image analysis and multimodal learning for clinical decision support, pages 240–248. Springer, 2017.
Define training step#
Here we take as input one batch of (data, target), train the model and compute the loss function.
Note that the MedicalFolderDataset class returns data as a tuple of (images, demographics), where:
  • images is a dict of {modality: image} (after image transformations)
  • demographics is a dict of {column_name: values} where the column names are taken from the demographics csv file while the target is a dict of {modality: image} (after target transformations).
In our case, the modality used is T1 for the input images, while the modality used for the target is label. We also ignore the values of the demographics data during training because the UNet model only takes images as input, but the code provided still shows the recommended way to handle such data.
class UNetTrainingPlan(TorchTrainingPlan):
        n_base_filters = model_args.get('base_filters',10)
        return UNet(
                spatial_dims = model_args.get('dimensions',3),
                in_channels = model_args.get('in_channels',1),
                out_channels = model_args.get('out_channels',2),
                channels = (n_base_filters,
                           2*n_base_filters,
                           4*n_base_filters),
                strides = (2,2),
                kernel_size=3,
                up_kernel_size=3,
                num_res_units=0,
                act='PRELU',
                norm='INSTANCE',
                dropout=0.0,
                bias=True,
                adn_ordering='NDA'
    def init_optimizer(self, optimizer_args):
        if optimizer_args.get('opt_name', 'not specified') == 'adamw':
            optimizer = AdamW(self.model().parameters(), lr=optimizer_args.get('lr', 0.001))
        else:
            optimizer = SGD(self.model().parameters(), lr=optimizer_args.get('lr', 0.001))
        return optimizer
        deps = [
            "from monai.losses.dice import DiceLoss",
            "import torch.nn as nn",
            'import torch.nn.functional as F',
            'from torch.optim import AdamW, SGD',
            'from monai.networks.nets import UNet',
            'from fedbiomed.common.logger import logger']
        return deps
    @staticmethod
    def get_dice_loss(output, target, epsilon=1e-9):
        loss = DiceLoss(include_background=False, sigmoid=False)
        return loss(output, target)
    @staticmethod
        return {}
        training_transform = Compose([AddChannel(), Resize(common_shape), NormalizeIntensity(),])
            demographics_transform=UNetTrainingPlan.demographics_transform)
        train_kwargs = {'batch_size': batch_size, 'shuffle': True}
    def training_step(self, data, target):
        #this function must return the loss to backward it
        img = data[0]['T1']
        demographics = data[1]
        logits = self.model().forward(img)
        output = F.softmax(logits, dim=1)
        loss = UNetTrainingPlan.get_dice_loss(output, target['label'])
        avg_loss = loss.mean()
        return avg_loss
    def testing_step(self, data, target):
        img = data[0]['T1']
        target = target['label']
        prediction = F.softmax(logits, dim=1)
        loss = UNetTrainingPlan.get_dice_loss(prediction, target)
        avg_loss = loss.mean()  # average per batch
        return avg_loss
Define Parameters#
Here you can define model_args and training_args, two dictionaries that contain parameters and hyperparameters for training and model definition. This provides a flexible way to explore the hyperparameter space without changing the TrainingPlan, which has potentially been fixed and validated by the clinical partners.
Try it yourself!#
Change any of the parameters below to explore the space of hyperparameters. Please be mindful of the limited available resources when changing parameters that may require more computing power, such as base_filters and especially batch_size.
model_args = {
    'in_channels': 1,
    'out_channels': 2,
    'dimensions': 3,
    'base_filters': 10,
training_args = {
    'batch_size': 4,
    'num_updates': 8,
    'dry_run': False,
    'log_interval': 2,
    'test_ratio' : 0.1,
    'test_on_global_updates': True,
    'optimizer_args': {
        'opt_name': 'adamw',
        'lr': 0.001
num_rounds = 15
Dry run your TrainingPlan locally#
Since we have an holdout dataset available locally, we are going to test that the TrainingPlan is able to run locally, before we perform the federated training.
Try it yourself!#
First, create a dataloader following these steps:
  1. instantiate a UNetTrainingPlan object
  2. call post_init on the training plan. Note: you will need to instantiate a TrainingArgs object from the training_args dict
  3. set the training plan’s dataset_path to /datasets/ixi/holdout
  4. Call the training_data function from the loaded experiment’s training plan to obtain a TorchDataManager
  5. Use the _dataset attribute of the data manager to instantiate a torch DataLoader (set a small batch size
Then, perform one training iteration to check that it completes without errors:
  1. create a for loop iterating on the dataloader
  2. call the training plan’s training_step method
  3. break after the first iteration
dryrun_tp = UNetTrainingPlan()
dryrun_tp.post_init(model_args, TrainingArgs(training_args, only_required=False))
dryrun_tp.dataset_path = '/datasets/ixi/holdout'
dryrun_dataloader = DataLoader(dryrun_tp.training_data()._dataset, batch_size=2)
for (inputs, targets) in dryrun_dataloader:
    avg_loss = dryrun_tp.training_step(inputs, targets)
    break
2023-07-03 15:25:34,004 fedbiomed DEBUG - using native torch optimizer
<class 'monai.transforms.utility.array.AddChannel'>: Class `AddChannel` has been deprecated since version 0.8. please use MetaTensor data type and monai.transforms.EnsureChannelFirst instead.
                 training_plan_class=UNetTrainingPlan,
                 training_args=training_args,
                 round_limit=num_rounds,
                 aggregator=FedAverage(),
                 tensorboard=True,
                 save_breakpoints=True
2023-07-03 15:25:34,228 fedbiomed INFO - Searching dataset with data tags: ['ixi-jupyter-sharkovsky'] for all nodes
2023-07-03 15:25:44,242 fedbiomed INFO - Node selected for training -> node_10797f2f-2524-4595-a1c6-f3c67e03add1
2023-07-03 15:25:44,243 fedbiomed INFO - Node selected for training -> node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1
2023-07-03 15:25:44,245 fedbiomed INFO - Checking data quality of federated datasets...
2023-07-03 15:25:44,249 fedbiomed DEBUG - using native torch optimizer
2023-07-03 15:25:44,250 fedbiomed DEBUG - Model file has been saved: /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py
2023-07-03 15:25:44,260 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py successful, with status code 201
2023-07-03 15:25:44,272 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_7055d84b-aace-4dc4-9662-91e55e544301.mpk successful, with status code 201
Run tensorboard#
Follow the instructions to obtain a port number, and run the commands below
tensorboard_dir = environ['TENSORBOARD_RESULTS_DIR']
tensorboard --logdir "$tensorboard_dir" --host 0.0.0.0 --port 6006
The tensorboard plots should look like this: image.png
Run the experiment#
print(f"Saving breakpoints to {exp.experimentation_folder()}")
Saving breakpoints to Experiment_0035
exp.run()
2023-07-03 15:25:45,809 fedbiomed INFO - Sampled nodes in round 0 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:25:45,809 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 0, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_7055d84b-aace-4dc4-9662-91e55e544301.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:25:45,810 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:25:45,810 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 0, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_7055d84b-aace-4dc4-9662-91e55e544301.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:25:45,811 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:25:46,075 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 NODE_ID: node_10797f2f-2524-4595-a1c6-f3c67e03add1
					 Round 1 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.669393
2023-07-03 15:25:46,283 fedbiomed INFO - TRAINING
					 Round 1 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.674166
2023-07-03 15:25:46,429 fedbiomed INFO - TRAINING
					 Round 1 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.652919
2023-07-03 15:25:46,736 fedbiomed INFO - TRAINING
					 Round 1 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.621792
2023-07-03 15:25:46,737 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 NODE_ID: node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1
					 Round 1 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.668537
2023-07-03 15:25:46,910 fedbiomed INFO - TRAINING
 					 Loss: 0.666687
2023-07-03 15:25:47,046 fedbiomed INFO - TRAINING
					 Round 1 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.574756
2023-07-03 15:25:47,054 fedbiomed INFO - TRAINING
 					 Loss: 0.657234
2023-07-03 15:25:47,352 fedbiomed INFO - TRAINING
					 Round 1 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.564428
2023-07-03 15:25:47,361 fedbiomed INFO - TRAINING
 					 Loss: 0.614738
2023-07-03 15:25:47,600 fedbiomed INFO - TRAINING
 					 Loss: 0.580021
2023-07-03 15:25:47,833 fedbiomed INFO - TRAINING
 					 Loss: 0.551721
2023-07-03 15:25:55,824 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_14f857d4-2825-4986-acf5-cb161fd72167.mpk
2023-07-03 15:25:55,829 fedbiomed DEBUG - download of file node_params_27bb3fa4-2838-4b13-8048-2aca18e48b48.mpk successful, with status code 200
2023-07-03 15:25:55,830 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_a3918182-53d9-4fbc-b8c0-d684c33883da.mpk
2023-07-03 15:25:55,833 fedbiomed DEBUG - download of file node_params_5066607e-e2d8-4d6b-8d15-7caa1c776142.mpk successful, with status code 200
2023-07-03 15:25:55,835 fedbiomed INFO - Nodes that successfully reply in round 0 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:25:55,852 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_5a192df2-9162-467b-bccc-4979b1201e3c.mpk successful, with status code 201
2023-07-03 15:25:55,853 fedbiomed INFO - Saved aggregated params for round 0 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_5a192df2-9162-467b-bccc-4979b1201e3c.mpk
2023-07-03 15:25:55,856 fedbiomed INFO - breakpoint for round 0 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0000
2023-07-03 15:25:55,856 fedbiomed INFO - Sampled nodes in round 1 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:25:55,857 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 1, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_5a192df2-9162-467b-bccc-4979b1201e3c.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:25:55,857 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:25:55,858 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 1, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_5a192df2-9162-467b-bccc-4979b1201e3c.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:25:55,859 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:25:56,044 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 2 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.558731
2023-07-03 15:25:56,190 fedbiomed INFO - TRAINING
					 Round 2 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.548774
2023-07-03 15:25:56,337 fedbiomed INFO - TRAINING
					 Round 2 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.528328
2023-07-03 15:25:56,624 fedbiomed INFO - TRAINING
					 Round 2 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.500181
2023-07-03 15:25:56,725 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 2 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.535123
2023-07-03 15:25:56,874 fedbiomed INFO - TRAINING
 					 Loss: 0.539535
2023-07-03 15:25:56,958 fedbiomed INFO - TRAINING
					 Round 2 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.506337
2023-07-03 15:25:57,026 fedbiomed INFO - TRAINING
 					 Loss: 0.524126
2023-07-03 15:25:57,248 fedbiomed INFO - TRAINING
					 Round 2 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.467335
2023-07-03 15:25:57,316 fedbiomed INFO - TRAINING
 					 Loss: 0.502197
2023-07-03 15:25:57,573 fedbiomed INFO - TRAINING
 					 Loss: 0.474423
2023-07-03 15:25:57,807 fedbiomed INFO - TRAINING
 					 Loss: 0.461409
2023-07-03 15:26:05,871 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_ac3b4469-a81a-4026-bc85-bc94ca8e76f3.mpk
2023-07-03 15:26:05,875 fedbiomed DEBUG - download of file node_params_edb7aa45-4445-49d9-9734-17f0a20dd3e4.mpk successful, with status code 200
2023-07-03 15:26:05,876 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_e99f6b93-801a-44f1-9664-fed7d3e840b0.mpk
2023-07-03 15:26:05,879 fedbiomed DEBUG - download of file node_params_0afd316c-bfeb-4f63-9e2b-ec50c8ce5f1c.mpk successful, with status code 200
2023-07-03 15:26:05,880 fedbiomed INFO - Nodes that successfully reply in round 1 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:26:05,895 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_3f384489-f597-4372-b489-4ae7268fa84f.mpk successful, with status code 201
2023-07-03 15:26:05,895 fedbiomed INFO - Saved aggregated params for round 1 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_3f384489-f597-4372-b489-4ae7268fa84f.mpk
2023-07-03 15:26:05,899 fedbiomed INFO - breakpoint for round 1 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0001
2023-07-03 15:26:05,899 fedbiomed INFO - Sampled nodes in round 2 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:26:05,900 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 2, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_3f384489-f597-4372-b489-4ae7268fa84f.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:26:05,900 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:26:05,901 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 2, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_3f384489-f597-4372-b489-4ae7268fa84f.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:26:05,901 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:26:06,085 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 3 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.467660
2023-07-03 15:26:06,225 fedbiomed INFO - TRAINING
					 Round 3 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.456158
2023-07-03 15:26:06,368 fedbiomed INFO - TRAINING
					 Round 3 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.449278
2023-07-03 15:26:06,654 fedbiomed INFO - TRAINING
					 Round 3 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.440290
2023-07-03 15:26:06,765 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 3 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.448526
2023-07-03 15:26:06,911 fedbiomed INFO - TRAINING
 					 Loss: 0.457173
2023-07-03 15:26:06,976 fedbiomed INFO - TRAINING
					 Round 3 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.424287
2023-07-03 15:26:07,056 fedbiomed INFO - TRAINING
 					 Loss: 0.447752
2023-07-03 15:26:07,293 fedbiomed INFO - TRAINING
					 Round 3 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.407967
2023-07-03 15:26:07,345 fedbiomed INFO - TRAINING
 					 Loss: 0.425157
2023-07-03 15:26:07,582 fedbiomed INFO - TRAINING
 					 Loss: 0.423018
2023-07-03 15:26:07,816 fedbiomed INFO - TRAINING
 					 Loss: 0.418149
2023-07-03 15:26:15,913 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_97a851a7-8e31-4280-a338-9dbcf4b49716.mpk
2023-07-03 15:26:15,918 fedbiomed DEBUG - download of file node_params_b225d01f-8b4d-4926-a797-f1eb3c20b8a6.mpk successful, with status code 200
2023-07-03 15:26:15,919 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_a0e8b335-39ec-4403-877c-b8a1eda08101.mpk
2023-07-03 15:26:15,922 fedbiomed DEBUG - download of file node_params_3ab4fda3-e4e3-463c-bdad-ceb9f7e61d13.mpk successful, with status code 200
2023-07-03 15:26:15,924 fedbiomed INFO - Nodes that successfully reply in round 2 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:26:15,939 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_90d0a3a6-6809-4576-939a-15ea78760e3a.mpk successful, with status code 201
2023-07-03 15:26:15,939 fedbiomed INFO - Saved aggregated params for round 2 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_90d0a3a6-6809-4576-939a-15ea78760e3a.mpk
2023-07-03 15:26:15,944 fedbiomed INFO - breakpoint for round 2 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0002
2023-07-03 15:26:15,944 fedbiomed INFO - Sampled nodes in round 3 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:26:15,945 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 3, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_90d0a3a6-6809-4576-939a-15ea78760e3a.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:26:15,945 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:26:15,946 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 3, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_90d0a3a6-6809-4576-939a-15ea78760e3a.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:26:15,946 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:26:16,131 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 4 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.403672
2023-07-03 15:26:16,274 fedbiomed INFO - TRAINING
					 Round 4 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.400611
2023-07-03 15:26:16,416 fedbiomed INFO - TRAINING
					 Round 4 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.398721
2023-07-03 15:26:16,699 fedbiomed INFO - TRAINING
					 Round 4 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.382506
2023-07-03 15:26:16,840 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 4 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.393137
2023-07-03 15:26:16,984 fedbiomed INFO - TRAINING
 					 Loss: 0.393294
2023-07-03 15:26:17,020 fedbiomed INFO - TRAINING
					 Round 4 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.369901
2023-07-03 15:26:17,132 fedbiomed INFO - TRAINING
 					 Loss: 0.392746
2023-07-03 15:26:17,314 fedbiomed INFO - TRAINING
					 Round 4 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.375875
2023-07-03 15:26:17,427 fedbiomed INFO - TRAINING
 					 Loss: 0.375468
2023-07-03 15:26:17,664 fedbiomed INFO - TRAINING
 					 Loss: 0.369481
2023-07-03 15:26:17,901 fedbiomed INFO - TRAINING
 					 Loss: 0.354816
2023-07-03 15:26:25,959 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_f2965acd-b381-42bd-bf27-28243bf09053.mpk
2023-07-03 15:26:25,963 fedbiomed DEBUG - download of file node_params_99a181ef-e33a-4f6a-8c5e-2ee531ffce4c.mpk successful, with status code 200
2023-07-03 15:26:25,964 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_f1167c66-8be6-4635-a53b-ae802a37ca67.mpk
2023-07-03 15:26:25,967 fedbiomed DEBUG - download of file node_params_45337c54-1d24-482c-82b5-599786a679e9.mpk successful, with status code 200
2023-07-03 15:26:25,969 fedbiomed INFO - Nodes that successfully reply in round 3 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:26:25,984 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_93402a18-b0d8-42aa-874c-7304f9f196e9.mpk successful, with status code 201
2023-07-03 15:26:25,985 fedbiomed INFO - Saved aggregated params for round 3 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_93402a18-b0d8-42aa-874c-7304f9f196e9.mpk
2023-07-03 15:26:25,991 fedbiomed INFO - breakpoint for round 3 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0003
2023-07-03 15:26:25,992 fedbiomed INFO - Sampled nodes in round 4 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:26:25,992 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 4, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_93402a18-b0d8-42aa-874c-7304f9f196e9.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:26:25,993 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:26:25,994 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 4, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_93402a18-b0d8-42aa-874c-7304f9f196e9.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:26:25,994 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:26:26,181 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 5 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.351257
2023-07-03 15:26:26,327 fedbiomed INFO - TRAINING
					 Round 5 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.374600
2023-07-03 15:26:26,470 fedbiomed INFO - TRAINING
					 Round 5 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.367414
2023-07-03 15:26:26,756 fedbiomed INFO - TRAINING
					 Round 5 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.360439
2023-07-03 15:26:26,882 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 5 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.344389
2023-07-03 15:26:27,028 fedbiomed INFO - TRAINING
 					 Loss: 0.348085
2023-07-03 15:26:27,060 fedbiomed INFO - TRAINING
					 Round 5 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.332643
2023-07-03 15:26:27,180 fedbiomed INFO - TRAINING
 					 Loss: 0.363724
2023-07-03 15:26:27,353 fedbiomed INFO - TRAINING
					 Round 5 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.334190
2023-07-03 15:26:27,469 fedbiomed INFO - TRAINING
 					 Loss: 0.335185
2023-07-03 15:26:27,706 fedbiomed INFO - TRAINING
 					 Loss: 0.348670
2023-07-03 15:26:27,941 fedbiomed INFO - TRAINING
 					 Loss: 0.316970
2023-07-03 15:26:36,006 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_bacf3723-e82c-4d94-94f0-feae048f577d.mpk
2023-07-03 15:26:36,010 fedbiomed DEBUG - download of file node_params_39c9f36d-ac3b-409d-a2b5-bdeab4b8cdb6.mpk successful, with status code 200
2023-07-03 15:26:36,011 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_e8315e0e-8109-44f3-86d6-0ba6b1811840.mpk
2023-07-03 15:26:36,014 fedbiomed DEBUG - download of file node_params_4e8b39da-f93b-4ca5-a29a-c0741a5f8ed7.mpk successful, with status code 200
2023-07-03 15:26:36,016 fedbiomed INFO - Nodes that successfully reply in round 4 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:26:36,033 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_eed04bb6-d633-4ea0-ab89-602d8d28c669.mpk successful, with status code 201
2023-07-03 15:26:36,034 fedbiomed INFO - Saved aggregated params for round 4 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_eed04bb6-d633-4ea0-ab89-602d8d28c669.mpk
2023-07-03 15:26:36,040 fedbiomed INFO - breakpoint for round 4 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0004
2023-07-03 15:26:36,041 fedbiomed INFO - Sampled nodes in round 5 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:26:36,041 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 5, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_eed04bb6-d633-4ea0-ab89-602d8d28c669.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:26:36,042 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:26:36,042 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 5, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_eed04bb6-d633-4ea0-ab89-602d8d28c669.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:26:36,043 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:26:36,228 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 6 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.346341
2023-07-03 15:26:36,370 fedbiomed INFO - TRAINING
					 Round 6 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.352756
2023-07-03 15:26:36,506 fedbiomed INFO - TRAINING
					 Round 6 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.318557
2023-07-03 15:26:36,788 fedbiomed INFO - TRAINING
					 Round 6 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.306386
2023-07-03 15:26:36,936 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 6 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.317866
2023-07-03 15:26:37,085 fedbiomed INFO - TRAINING
 					 Loss: 0.316483
2023-07-03 15:26:37,102 fedbiomed INFO - TRAINING
					 Round 6 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.299668
2023-07-03 15:26:37,237 fedbiomed INFO - TRAINING
 					 Loss: 0.311033
2023-07-03 15:26:37,416 fedbiomed INFO - TRAINING
					 Round 6 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.306905
2023-07-03 15:26:37,525 fedbiomed INFO - TRAINING
 					 Loss: 0.287525
2023-07-03 15:26:37,767 fedbiomed INFO - TRAINING
 					 Loss: 0.296751
2023-07-03 15:26:37,998 fedbiomed INFO - TRAINING
 					 Loss: 0.280906
2023-07-03 15:26:46,055 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_f3ef3bc2-dda5-4238-a019-c9a4d01fee21.mpk
2023-07-03 15:26:46,059 fedbiomed DEBUG - download of file node_params_491515ee-b3ac-465a-8928-965f1d20bc66.mpk successful, with status code 200
2023-07-03 15:26:46,060 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_61cf76e4-2e6d-46c1-9385-ecec86903889.mpk
2023-07-03 15:26:46,063 fedbiomed DEBUG - download of file node_params_20a0e85a-babe-49d9-bf29-7dba29d04d51.mpk successful, with status code 200
2023-07-03 15:26:46,064 fedbiomed INFO - Nodes that successfully reply in round 5 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:26:46,079 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_3d345bc3-0b1a-46e8-a121-36778af85492.mpk successful, with status code 201
2023-07-03 15:26:46,079 fedbiomed INFO - Saved aggregated params for round 5 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_3d345bc3-0b1a-46e8-a121-36778af85492.mpk
2023-07-03 15:26:46,087 fedbiomed INFO - breakpoint for round 5 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0005
2023-07-03 15:26:46,088 fedbiomed INFO - Sampled nodes in round 6 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:26:46,089 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 6, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_3d345bc3-0b1a-46e8-a121-36778af85492.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:26:46,089 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:26:46,090 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 6, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_3d345bc3-0b1a-46e8-a121-36778af85492.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:26:46,091 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:26:46,271 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 7 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.290740
2023-07-03 15:26:46,413 fedbiomed INFO - TRAINING
					 Round 7 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.293899
2023-07-03 15:26:46,555 fedbiomed INFO - TRAINING
					 Round 7 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.305884
2023-07-03 15:26:46,834 fedbiomed INFO - TRAINING
					 Round 7 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.280895
2023-07-03 15:26:47,059 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 7 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.278067
2023-07-03 15:26:47,145 fedbiomed INFO - TRAINING
					 Round 7 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.269260
2023-07-03 15:26:47,202 fedbiomed INFO - TRAINING
 					 Loss: 0.281160
2023-07-03 15:26:47,346 fedbiomed INFO - TRAINING
 					 Loss: 0.280498
2023-07-03 15:26:47,448 fedbiomed INFO - TRAINING
					 Round 7 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.261392
2023-07-03 15:26:47,618 fedbiomed INFO - TRAINING
 					 Loss: 0.268134
2023-07-03 15:26:47,850 fedbiomed INFO - TRAINING
 					 Loss: 0.255430
2023-07-03 15:26:48,080 fedbiomed INFO - TRAINING
 					 Loss: 0.252412
2023-07-03 15:26:56,103 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_0c22111e-1921-43a5-b255-e755b8020787.mpk
2023-07-03 15:26:56,107 fedbiomed DEBUG - download of file node_params_972367aa-e104-47c3-8082-8e2d1cb5dc9d.mpk successful, with status code 200
2023-07-03 15:26:56,108 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_a743af30-fba4-477a-a616-5c8471953b17.mpk
2023-07-03 15:26:56,111 fedbiomed DEBUG - download of file node_params_78f7ea96-48d1-404e-b2ee-ed7ae63853e6.mpk successful, with status code 200
2023-07-03 15:26:56,112 fedbiomed INFO - Nodes that successfully reply in round 6 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:26:56,127 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_10235386-b138-44ff-94f7-a6d6c71470c3.mpk successful, with status code 201
2023-07-03 15:26:56,127 fedbiomed INFO - Saved aggregated params for round 6 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_10235386-b138-44ff-94f7-a6d6c71470c3.mpk
2023-07-03 15:26:56,137 fedbiomed INFO - breakpoint for round 6 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0006
2023-07-03 15:26:56,137 fedbiomed INFO - Sampled nodes in round 7 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:26:56,138 fedbiomed INFO - Sending request
					 To: node_10797f2f-2524-4595-a1c6-f3c67e03add1
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 7, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_10235386-b138-44ff-94f7-a6d6c71470c3.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:26:56,138 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:26:56,139 fedbiomed INFO - Sending request
					 To: node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 7, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_10235386-b138-44ff-94f7-a6d6c71470c3.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:26:56,139 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:26:56,325 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 8 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.260062
2023-07-03 15:26:56,469 fedbiomed INFO - TRAINING
					 Round 8 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.276170
2023-07-03 15:26:56,616 fedbiomed INFO - TRAINING
					 Round 8 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.266267
2023-07-03 15:26:56,895 fedbiomed INFO - TRAINING
					 Round 8 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.257818
2023-07-03 15:26:57,031 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 8 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.248313
2023-07-03 15:26:57,177 fedbiomed INFO - TRAINING
 					 Loss: 0.243596
2023-07-03 15:26:57,215 fedbiomed INFO - TRAINING
					 Round 8 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.249228
2023-07-03 15:26:57,322 fedbiomed INFO - TRAINING
 					 Loss: 0.265798
2023-07-03 15:26:57,497 fedbiomed INFO - TRAINING
					 Round 8 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.243402
2023-07-03 15:26:57,590 fedbiomed INFO - TRAINING
 					 Loss: 0.255732
2023-07-03 15:26:57,828 fedbiomed INFO - TRAINING
 					 Loss: 0.240263
2023-07-03 15:26:58,057 fedbiomed INFO - TRAINING
 					 Loss: 0.240697
2023-07-03 15:27:06,152 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_dc23bfd6-9b70-4932-b051-e4b1c17aa6e1.mpk
2023-07-03 15:27:06,156 fedbiomed DEBUG - download of file node_params_d9af3bd4-87a1-4dbc-96ec-5f511e24c9b8.mpk successful, with status code 200
2023-07-03 15:27:06,157 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_d2f32ef3-32fa-4c25-9b34-066e68521816.mpk
2023-07-03 15:27:06,160 fedbiomed DEBUG - download of file node_params_ea3a9f32-c492-4121-b788-daa59715ebc1.mpk successful, with status code 200
2023-07-03 15:27:06,161 fedbiomed INFO - Nodes that successfully reply in round 7 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:27:06,176 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_aadfc76b-44db-4d37-9b3b-1b591defa61e.mpk successful, with status code 201
2023-07-03 15:27:06,176 fedbiomed INFO - Saved aggregated params for round 7 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_aadfc76b-44db-4d37-9b3b-1b591defa61e.mpk
2023-07-03 15:27:06,186 fedbiomed INFO - breakpoint for round 7 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0007
2023-07-03 15:27:06,187 fedbiomed INFO - Sampled nodes in round 8 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:27:06,187 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 8, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_aadfc76b-44db-4d37-9b3b-1b591defa61e.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:27:06,187 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:27:06,188 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 8, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_aadfc76b-44db-4d37-9b3b-1b591defa61e.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:27:06,189 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:27:06,376 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 9 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.253103
2023-07-03 15:27:06,521 fedbiomed INFO - TRAINING
					 Round 9 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.254661
2023-07-03 15:27:06,667 fedbiomed INFO - TRAINING
					 Round 9 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.242832
2023-07-03 15:27:06,964 fedbiomed INFO - TRAINING
					 Round 9 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.232194
2023-07-03 15:27:07,072 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 9 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.230317
2023-07-03 15:27:07,223 fedbiomed INFO - TRAINING
 					 Loss: 0.239177
2023-07-03 15:27:07,267 fedbiomed INFO - TRAINING
					 Round 9 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.220112
2023-07-03 15:27:07,365 fedbiomed INFO - TRAINING
 					 Loss: 0.234501
2023-07-03 15:27:07,561 fedbiomed INFO - TRAINING
					 Round 9 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.204340
2023-07-03 15:27:07,649 fedbiomed INFO - TRAINING
 					 Loss: 0.213800
2023-07-03 15:27:07,881 fedbiomed INFO - TRAINING
 					 Loss: 0.214610
2023-07-03 15:27:08,113 fedbiomed INFO - TRAINING
 					 Loss: 0.207103
2023-07-03 15:27:16,201 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_070610ff-8415-468f-8a95-bd6baaa1623d.mpk
2023-07-03 15:27:16,205 fedbiomed DEBUG - download of file node_params_3f6dde66-d8ff-4a67-8f5f-8703c63516ba.mpk successful, with status code 200
2023-07-03 15:27:16,206 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_1f7f2f7a-1b29-453e-9595-7fe79ab9757e.mpk
2023-07-03 15:27:16,210 fedbiomed DEBUG - download of file node_params_e8d19be2-2972-4b93-90a1-208b72cf5776.mpk successful, with status code 200
2023-07-03 15:27:16,211 fedbiomed INFO - Nodes that successfully reply in round 8 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:27:16,225 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_9be2ed78-2916-4b40-992b-9be12b20621b.mpk successful, with status code 201
2023-07-03 15:27:16,225 fedbiomed INFO - Saved aggregated params for round 8 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_9be2ed78-2916-4b40-992b-9be12b20621b.mpk
2023-07-03 15:27:16,236 fedbiomed INFO - breakpoint for round 8 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0008
2023-07-03 15:27:16,236 fedbiomed INFO - Sampled nodes in round 9 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:27:16,237 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 9, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_9be2ed78-2916-4b40-992b-9be12b20621b.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:27:16,237 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:27:16,238 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 9, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_9be2ed78-2916-4b40-992b-9be12b20621b.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:27:16,238 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:27:16,421 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 10 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.219118
2023-07-03 15:27:16,563 fedbiomed INFO - TRAINING
					 Round 10 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.217602
2023-07-03 15:27:16,705 fedbiomed INFO - TRAINING
					 Round 10 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.234990
2023-07-03 15:27:16,994 fedbiomed INFO - TRAINING
					 Round 10 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.209549
2023-07-03 15:27:17,110 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 10 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.206117
2023-07-03 15:27:17,269 fedbiomed INFO - TRAINING
 					 Loss: 0.202606
2023-07-03 15:27:17,316 fedbiomed INFO - TRAINING
					 Round 10 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.205439
2023-07-03 15:27:17,413 fedbiomed INFO - TRAINING
 					 Loss: 0.210446
2023-07-03 15:27:17,615 fedbiomed INFO - TRAINING
					 Round 10 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.203125
2023-07-03 15:27:17,707 fedbiomed INFO - TRAINING
 					 Loss: 0.200621
2023-07-03 15:27:17,943 fedbiomed INFO - TRAINING
 					 Loss: 0.193945
2023-07-03 15:27:18,176 fedbiomed INFO - TRAINING
 					 Loss: 0.179735
2023-07-03 15:27:26,250 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_71fb7a70-1916-4c7d-8582-2ba69371b787.mpk
2023-07-03 15:27:26,255 fedbiomed DEBUG - download of file node_params_cf060acc-caa2-4da5-b24a-cfe23433138a.mpk successful, with status code 200
2023-07-03 15:27:26,256 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_238965d9-c731-4fe6-a8bd-9dbd9cfd9515.mpk
2023-07-03 15:27:26,259 fedbiomed DEBUG - download of file node_params_5c9260a4-c00e-408d-add3-6ecf46cf6aab.mpk successful, with status code 200
2023-07-03 15:27:26,261 fedbiomed INFO - Nodes that successfully reply in round 9 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:27:26,275 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_8a903bea-9b6d-4b61-a84e-05008409b176.mpk successful, with status code 201
2023-07-03 15:27:26,275 fedbiomed INFO - Saved aggregated params for round 9 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_8a903bea-9b6d-4b61-a84e-05008409b176.mpk
2023-07-03 15:27:26,288 fedbiomed INFO - breakpoint for round 9 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0009
2023-07-03 15:27:26,289 fedbiomed INFO - Sampled nodes in round 10 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:27:26,289 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 10, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_8a903bea-9b6d-4b61-a84e-05008409b176.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:27:26,290 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:27:26,291 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 10, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_8a903bea-9b6d-4b61-a84e-05008409b176.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:27:26,291 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:27:26,474 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 11 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.206012
2023-07-03 15:27:26,616 fedbiomed INFO - TRAINING
					 Round 11 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.211716
2023-07-03 15:27:26,760 fedbiomed INFO - TRAINING
					 Round 11 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.211098
2023-07-03 15:27:27,046 fedbiomed INFO - TRAINING
					 Round 11 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.187615
2023-07-03 15:27:27,164 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 11 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.181723
2023-07-03 15:27:27,309 fedbiomed INFO - TRAINING
 					 Loss: 0.186365
2023-07-03 15:27:27,361 fedbiomed INFO - TRAINING
					 Round 11 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.204853
2023-07-03 15:27:27,472 fedbiomed INFO - TRAINING
 					 Loss: 0.191783
2023-07-03 15:27:27,666 fedbiomed INFO - TRAINING
					 Round 11 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.180141
2023-07-03 15:27:27,765 fedbiomed INFO - TRAINING
 					 Loss: 0.192469
2023-07-03 15:27:27,997 fedbiomed INFO - TRAINING
 					 Loss: 0.178307
2023-07-03 15:27:28,229 fedbiomed INFO - TRAINING
 					 Loss: 0.175291
2023-07-03 15:27:36,304 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_6a04bbac-c7bc-43b7-bd6b-c86edd0e1a52.mpk
2023-07-03 15:27:36,308 fedbiomed DEBUG - download of file node_params_6a84dc84-e2af-4f62-aecc-34d6f26868f5.mpk successful, with status code 200
2023-07-03 15:27:36,309 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_bbb3bf74-3773-4559-af65-e1049684567d.mpk
2023-07-03 15:27:36,312 fedbiomed DEBUG - download of file node_params_dc045cc4-94da-4cf2-9874-ffae879292b6.mpk successful, with status code 200
2023-07-03 15:27:36,313 fedbiomed INFO - Nodes that successfully reply in round 10 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:27:36,328 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_1acd6e7b-7051-4172-ae6f-d75836dfed8b.mpk successful, with status code 201
2023-07-03 15:27:36,329 fedbiomed INFO - Saved aggregated params for round 10 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_1acd6e7b-7051-4172-ae6f-d75836dfed8b.mpk
2023-07-03 15:27:36,341 fedbiomed INFO - breakpoint for round 10 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0010
2023-07-03 15:27:36,342 fedbiomed INFO - Sampled nodes in round 11 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:27:36,342 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 11, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_1acd6e7b-7051-4172-ae6f-d75836dfed8b.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:27:36,342 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:27:36,343 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 11, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_1acd6e7b-7051-4172-ae6f-d75836dfed8b.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:27:36,344 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:27:36,529 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 NODE_ID: node_10797f2f-2524-4595-a1c6-f3c67e03add1
					 Round 12 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.192321
2023-07-03 15:27:36,672 fedbiomed INFO - TRAINING
					 Round 12 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.175604
2023-07-03 15:27:36,817 fedbiomed INFO - TRAINING
					 Round 12 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.192354
2023-07-03 15:27:37,099 fedbiomed INFO - TRAINING
					 Round 12 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.180088
2023-07-03 15:27:37,217 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 NODE_ID: node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1
					 Round 12 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.169724
2023-07-03 15:27:37,365 fedbiomed INFO - TRAINING
 					 Loss: 0.173665
2023-07-03 15:27:37,430 fedbiomed INFO - TRAINING
					 Round 12 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.161954
2023-07-03 15:27:37,512 fedbiomed INFO - TRAINING
 					 Loss: 0.174298
2023-07-03 15:27:37,743 fedbiomed INFO - TRAINING
					 Round 12 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.155939
2023-07-03 15:27:37,807 fedbiomed INFO - TRAINING
 					 Loss: 0.167927
2023-07-03 15:27:38,045 fedbiomed INFO - TRAINING
 					 Loss: 0.166235
2023-07-03 15:27:38,283 fedbiomed INFO - TRAINING
 					 Loss: 0.155272
2023-07-03 15:27:46,356 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_22fedfae-4ae1-4ce2-af84-ba7c0ad08edf.mpk
2023-07-03 15:27:46,360 fedbiomed DEBUG - download of file node_params_15f8efab-7613-4d5d-8897-d4b2bb1338a6.mpk successful, with status code 200
2023-07-03 15:27:46,361 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_9ce14dd2-a62b-4b2b-8961-126111930632.mpk
2023-07-03 15:27:46,364 fedbiomed DEBUG - download of file node_params_2fa7abfc-ccda-4518-af2e-6dd7c5853ae6.mpk successful, with status code 200
2023-07-03 15:27:46,366 fedbiomed INFO - Nodes that successfully reply in round 11 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:27:46,383 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_2e1c891a-b0ae-48f1-86b4-a0d889eb42a1.mpk successful, with status code 201
2023-07-03 15:27:46,383 fedbiomed INFO - Saved aggregated params for round 11 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_2e1c891a-b0ae-48f1-86b4-a0d889eb42a1.mpk
2023-07-03 15:27:46,399 fedbiomed INFO - breakpoint for round 11 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0011
2023-07-03 15:27:46,399 fedbiomed INFO - Sampled nodes in round 12 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:27:46,400 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 12, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_2e1c891a-b0ae-48f1-86b4-a0d889eb42a1.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:27:46,400 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:27:46,401 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 12, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_2e1c891a-b0ae-48f1-86b4-a0d889eb42a1.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:27:46,401 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:27:46,580 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 13 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.168423
2023-07-03 15:27:46,724 fedbiomed INFO - TRAINING
					 Round 13 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.159756
2023-07-03 15:27:46,872 fedbiomed INFO - TRAINING
					 Round 13 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.175157
2023-07-03 15:27:47,152 fedbiomed INFO - TRAINING
					 Round 13 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.160788
2023-07-03 15:27:47,336 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 13 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.153615
2023-07-03 15:27:47,467 fedbiomed INFO - TRAINING
					 Round 13 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.164476
2023-07-03 15:27:47,482 fedbiomed INFO - TRAINING
 					 Loss: 0.153208
2023-07-03 15:27:47,635 fedbiomed INFO - TRAINING
 					 Loss: 0.144645
2023-07-03 15:27:47,763 fedbiomed INFO - TRAINING
					 Round 13 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.148582
2023-07-03 15:27:47,925 fedbiomed INFO - TRAINING
 					 Loss: 0.147024
2023-07-03 15:27:48,209 fedbiomed INFO - TRAINING
 					 Loss: 0.143274
2023-07-03 15:27:48,454 fedbiomed INFO - TRAINING
 					 Loss: 0.135392
2023-07-03 15:27:56,413 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_29dfc20e-46ca-4a5f-a571-e806ebf69007.mpk
2023-07-03 15:27:56,417 fedbiomed DEBUG - download of file node_params_54822ef5-b9b4-4e14-a005-770b7a15d694.mpk successful, with status code 200
2023-07-03 15:27:56,418 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_0a5af092-5a05-43e7-bf4d-a872036ffe04.mpk
2023-07-03 15:27:56,421 fedbiomed DEBUG - download of file node_params_beca141f-633a-45c4-b05c-d8195b6860e2.mpk successful, with status code 200
2023-07-03 15:27:56,423 fedbiomed INFO - Nodes that successfully reply in round 12 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:27:56,437 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_6d539017-1a60-40c6-87a1-96f99c24b30c.mpk successful, with status code 201
2023-07-03 15:27:56,437 fedbiomed INFO - Saved aggregated params for round 12 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_6d539017-1a60-40c6-87a1-96f99c24b30c.mpk
2023-07-03 15:27:56,454 fedbiomed INFO - breakpoint for round 12 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0012
2023-07-03 15:27:56,454 fedbiomed INFO - Sampled nodes in round 13 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:27:56,454 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 13, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_6d539017-1a60-40c6-87a1-96f99c24b30c.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:27:56,455 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:27:56,456 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 13, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_6d539017-1a60-40c6-87a1-96f99c24b30c.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:27:56,456 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:27:56,651 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 14 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.146723
2023-07-03 15:27:56,792 fedbiomed INFO - TRAINING
					 Round 14 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.161997
2023-07-03 15:27:56,931 fedbiomed INFO - TRAINING
					 Round 14 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.202094
2023-07-03 15:27:57,208 fedbiomed INFO - TRAINING
					 Round 14 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.139733
2023-07-03 15:27:57,370 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 14 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.136182
2023-07-03 15:27:57,516 fedbiomed INFO - TRAINING
 					 Loss: 0.138592
2023-07-03 15:27:57,530 fedbiomed INFO - TRAINING
					 Round 14 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.162032
2023-07-03 15:27:57,652 fedbiomed INFO - TRAINING
 					 Loss: 0.154214
2023-07-03 15:27:57,825 fedbiomed INFO - TRAINING
					 Round 14 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.172374
2023-07-03 15:27:57,931 fedbiomed INFO - TRAINING
 					 Loss: 0.143040
2023-07-03 15:27:58,164 fedbiomed INFO - TRAINING
 					 Loss: 0.152959
2023-07-03 15:27:58,393 fedbiomed INFO - TRAINING
 					 Loss: 0.129842
2023-07-03 15:28:06,468 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_44b763a0-2b35-4704-9e66-a35217f26b71.mpk
2023-07-03 15:28:06,472 fedbiomed DEBUG - download of file node_params_fc09ba74-d573-4277-bfe2-3ca21b6d3b06.mpk successful, with status code 200
2023-07-03 15:28:06,473 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_301b8b8f-f271-4399-aa35-344b41139265.mpk
2023-07-03 15:28:06,475 fedbiomed DEBUG - download of file node_params_9f4b375d-4bfb-49f7-a1a1-b0ee12e0bf4b.mpk successful, with status code 200
2023-07-03 15:28:06,477 fedbiomed INFO - Nodes that successfully reply in round 13 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:28:06,492 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_4113e476-cbbb-4b11-8733-5977233319c6.mpk successful, with status code 201
2023-07-03 15:28:06,492 fedbiomed INFO - Saved aggregated params for round 13 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_4113e476-cbbb-4b11-8733-5977233319c6.mpk
2023-07-03 15:28:06,510 fedbiomed INFO - breakpoint for round 13 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0013
2023-07-03 15:28:06,510 fedbiomed INFO - Sampled nodes in round 14 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:28:06,511 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 14, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_4113e476-cbbb-4b11-8733-5977233319c6.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_ae4dd6a8-1227-4379-8d3c-7a2caa0d9503'}
2023-07-03 15:28:06,511 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:28:06,512 fedbiomed INFO - Sending request
					 Request: : Perform training with the arguments: {'researcher_id': 'researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87', 'job_id': '68a226ac-6cdb-4a84-a21f-60303da18ecc', 'training_args': {'batch_size': 4, 'num_updates': 8, 'dry_run': False, 'log_interval': 2, 'test_ratio': 0.1, 'test_on_global_updates': True, 'test_on_local_updates': False, 'optimizer_args': {'opt_name': 'adamw', 'lr': 0.001}, 'epochs': None, 'batch_maxnum': None, 'test_metric': None, 'test_metric_args': {}, 'fedprox_mu': None, 'use_gpu': False, 'dp_args': None, 'share_persistent_buffers': True}, 'training': True, 'model_args': {'in_channels': 1, 'out_channels': 2, 'dimensions': 3, 'base_filters': 10}, 'round': 14, 'secagg_servkey_id': None, 'secagg_biprime_id': None, 'secagg_random': None, 'secagg_clipping_range': None, 'command': 'train', 'training_plan_url': 'http://localhost:8844/media/uploads/2023/07/03/my_model_fc0d2921-9797-4a5c-94fa-4beda077391d.py', 'params_url': 'http://localhost:8844/media/uploads/2023/07/03/aggregated_params_4113e476-cbbb-4b11-8733-5977233319c6.mpk', 'training_plan_class': 'UNetTrainingPlan', 'dataset_id': 'dataset_0e27e24b-46a6-4440-a189-e5bfd80a0f24', 'protocol_version': '1'}
2023-07-03 15:28:06,512 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:28:06,699 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 15 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.137983
2023-07-03 15:28:06,845 fedbiomed INFO - TRAINING
					 Round 15 | Iteration: 1/8 (12%) | Samples: 4/32
 					 Loss: 0.149709
2023-07-03 15:28:06,992 fedbiomed INFO - TRAINING
					 Round 15 | Iteration: 2/8 (25%) | Samples: 8/32
 					 Loss: 0.160152
2023-07-03 15:28:07,287 fedbiomed INFO - TRAINING
					 Round 15 | Iteration: 4/8 (50%) | Samples: 16/32
 					 Loss: 0.134322
2023-07-03 15:28:07,386 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 15 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.130700
2023-07-03 15:28:07,531 fedbiomed INFO - TRAINING
 					 Loss: 0.125600
2023-07-03 15:28:07,587 fedbiomed INFO - TRAINING
					 Round 15 | Iteration: 6/8 (75%) | Samples: 24/32
 					 Loss: 0.131024
2023-07-03 15:28:07,680 fedbiomed INFO - TRAINING
 					 Loss: 0.135730
2023-07-03 15:28:07,882 fedbiomed INFO - TRAINING
					 Round 15 | Iteration: 8/8 (100%) | Samples: 32/32
 					 Loss: 0.130599
2023-07-03 15:28:07,971 fedbiomed INFO - TRAINING
 					 Loss: 0.130924
2023-07-03 15:28:08,204 fedbiomed INFO - TRAINING
 					 Loss: 0.114719
2023-07-03 15:28:08,438 fedbiomed INFO - TRAINING
 					 Loss: 0.120319
2023-07-03 15:28:16,525 fedbiomed INFO - Downloading model params after training on node_10797f2f-2524-4595-a1c6-f3c67e03add1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_cb213f31-0cac-4a9f-b435-0cd4f1aedcba.mpk
2023-07-03 15:28:16,529 fedbiomed DEBUG - download of file node_params_ceef462c-f386-482a-8d94-146ec0c85a26.mpk successful, with status code 200
2023-07-03 15:28:16,530 fedbiomed INFO - Downloading model params after training on node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1 - from http://localhost:8844/media/uploads/2023/07/03/node_params_c04a81c2-7eb1-46c8-9933-89d20fb37d2d.mpk
2023-07-03 15:28:16,533 fedbiomed DEBUG - download of file node_params_476676c1-eaa1-48eb-861c-383dd28d0095.mpk successful, with status code 200
2023-07-03 15:28:16,534 fedbiomed INFO - Nodes that successfully reply in round 14 ['node_10797f2f-2524-4595-a1c6-f3c67e03add1', 'node_e27ab041-6133-4e2f-b0ce-afa0a0c59fa1']
2023-07-03 15:28:16,548 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_5b849352-a583-4a67-8e3a-43fc3ddb9632.mpk successful, with status code 201
2023-07-03 15:28:16,549 fedbiomed INFO - Saved aggregated params for round 14 in /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_5b849352-a583-4a67-8e3a-43fc3ddb9632.mpk
2023-07-03 15:28:16,568 fedbiomed INFO - breakpoint for round 14 saved at /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0014
2023-07-03 15:28:16,568 fedbiomed INFO - Sending request
					 Request: :Perform final validation on aggregated parameters
2023-07-03 15:28:16,569 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:28:16,569 fedbiomed INFO - Sending request
2023-07-03 15:28:16,570 fedbiomed DEBUG - researcher_dba292ff-efe1-40ad-a1c6-1a4d5f6bbd87
2023-07-03 15:28:16,756 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 16 | Iteration: 1/1 (100%) | Samples: 6/6
 					 Custom: 0.133379
2023-07-03 15:28:17,402 fedbiomed INFO - VALIDATION ON GLOBAL UPDATES
					 Round 16 | Iteration: 1/1 (100%) | Samples: 30/30
 					 Custom: 0.118207
15
Task 5: Validate on a local holdout set #
To ensure consistency and simplify our life, we try to reuse the already-available code as much as possible. Note that this process assumes that the held-out data is stored locally on the machine.
Create an instance of the global model#
First, we create an instance of the model using the parameters from the latest aggregation round.
exp_folder = exp.experimentation_folder()
#exp_folder = 'Experiment_0030'
breakpoint_num = num_rounds - 1
breakpoint_dir = os.path.join(environ['EXPERIMENTS_DIR'], exp_folder, f'breakpoint_{breakpoint_num:04d}')
Try it yourself!#
  1. Call the post_init function to initialize the model in the newly loaded experiment’s training plan (Note, you will need to create a TrainingArgs object)
  2. extract the model
  3. call the model’s load_state_dict, by passing as argument the model weights obtained from the loaded experiment’s _aggregated_params
loaded_exp = Experiment.load_breakpoint(breakpoint_dir)
loaded_exp.training_plan().post_init(model_args, TrainingArgs(training_args, only_required=False))
valid_model = loaded_exp.training_plan().model()
valid_model.load_state_dict(loaded_exp._aggregated_params[num_rounds-1]['params']['model_weights'])
2023-07-03 15:28:26,595 fedbiomed DEBUG - found json file containing states at                breakpoint_0014.json
2023-07-03 15:28:26,596 fedbiomed DEBUG - Experiment not fully configured yet: no valid training plan, training_plan_class=UNetTrainingPlan training_plan_class_path=None
2023-07-03 15:28:26,597 fedbiomed INFO - Checking data quality of federated datasets...
Secure RNG turned off. This is perfectly fine for experimentation as it allows for much faster training performance, but remember to turn it on and retrain one last time before production with ``secure_mode`` turned on.
2023-07-03 15:28:26,601 fedbiomed DEBUG - using native torch optimizer
2023-07-03 15:28:26,603 fedbiomed DEBUG - Model file has been saved: /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/my_model_7e777cc4-4831-4475-b13a-086530169ea5.py
2023-07-03 15:28:26,612 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/my_model_7e777cc4-4831-4475-b13a-086530169ea5.py successful, with status code 201
2023-07-03 15:28:26,623 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/aggregated_params_9bfda251-434c-4483-80cc-06d79f695b6a.mpk successful, with status code 201
2023-07-03 15:28:26,624 fedbiomed INFO - Removing tensorboard logs from previous experiment
2023-07-03 15:28:26,638 fedbiomed DEBUG - HTTP POST request of file /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0014/aggregated_params_current.mpk successful, with status code 201
2023-07-03 15:28:26,643 fedbiomed INFO - Experimentation reload from /home/jupyter-sharkovsky/fedbiomed/var/experiments/Experiment_0035/breakpoint_0014 successful!
2023-07-03 15:28:26,646 fedbiomed DEBUG - using native torch optimizer
<All keys matched successfully>
Define a validation data loader#
We extract the validation data loader from the training plan as well. This requires some knowledge about the internals of the MedicalFolderDataset class. At the end of the process, calling the split function with a ratio of 0 will return a data loader that loads all of the data.
Try it yourself!#
Call the training_data function from the loaded experiment’s training plan to obtain a TorchDataManager. Use the _dataset attribute of the data manager to instantiate a torch DataLoader.
Note: use a batch size of 1 for local validation.
loaded_exp.training_plan().dataset_path = '/datasets/ixi/holdout'
val_data_manager = loaded_exp.training_plan().training_data(batch_size=1)
val_data_loader = DataLoader(val_data_manager._dataset, batch_size=1)
<class 'monai.transforms.utility.array.AddChannel'>: Class `AddChannel` has been deprecated since version 0.8. please use MetaTensor data type and monai.transforms.EnsureChannelFirst instead.
Compute the loss on validation images#
Try it yourself!#
  1. Iterate over the validation dataset using the DataLoader defined above.
  2. Compute the predictions by manually calling the model forward and F.softmax methods.
  3. Compute the loss by calling the UNetTrainingPlan.get_dice_loss function.
  4. Store the loss values in a list.
Attention: do not forget to set valid_model.eval() and to use the torch.no_grad context.
losses = []
valid_model.eval()
with torch.no_grad():
    for (images, demographics), targets in val_data_loader:
        image = images['T1']
        target = targets['label']
        logits = valid_model.forward(image)
        prediction = F.softmax(logits, dim=1)
        loss = UNetTrainingPlan.get_dice_loss(prediction, target)
        losses.append(loss.detach().numpy())
loss_array = np.array(losses)
print(f'Minumum: {loss_array.min():0.3f} '
      f'Mean: {loss_array.mean():0.3f} '
      f'StdDev: {loss_array.std():0.3f} '
      f'Maximum: {loss_array.max():0.3f} ')
Minumum: 0.111 Mean: 0.123 StdDev: 0.007 Maximum: 0.152
Visualize the outputs#
As a bonus, we visualize the outputs of our model on the holdout dataset.
val_data_loader_iter = iter(val_data_loader)
Try it yourself!#
Create a grid of 4x2 images. In each row, plot a slice of the original on the left overlayed with the ground truth, and the same slice of the original on the right overlayed with the prediction. Insert the loss value in the title of the image. Remember that to compute the predictions you need to pass the whole 3d image to model.forward, not just a slice.
fig, ax = plt.subplots(4,2, figsize=(8,16))
slice_to_plot = 24
for i in range(4):
    (image_modalities, demographics), target = next(val_data_loader_iter)
    img = image_modalities['T1'][0, 0, ..., slice_to_plot]
    ax[i][0].imshow(img, cmap='bone', interpolation='none')
    label = target['label'][0, 1, ..., slice_to_plot]
    plot = ax[i][0].imshow(np.ma.masked_where(
                            label < 0.5,
                            label), cmap='winter', alpha=0.5, interpolation='none', vmin=0., vmax=1.)
    ax[i][0].invert_yaxis()
    ax[i][0].set_title('Ground truth overlay')
    ax[i][1].imshow(img, cmap='bone', interpolation='none')
    prediction_3d = F.softmax(valid_model.forward(image_modalities['T1']), dim=1)
    prediction = prediction_3d[0, 1, ..., slice_to_plot].detach().numpy()
    plot = ax[i][1].imshow(np.ma.masked_where(
        prediction < 0.5,
        prediction), cmap='winter', alpha=0.5, interpolation='none', vmin=0., vmax=1.)
    ax[i][1].invert_yaxis()
    ax[i][1].set_title(f'Prediction overlay - loss: {losses[i]:0.3f}')
fig.tight_layout(pad=3.0)
fig.colorbar(plot, ax=ax, location='bottom')
<matplotlib.colorbar.Colorbar at 0x7ff94ae6d340>
../_images/45f5ef258928ef1e98d558710575217976a0eb43b653623e8f782dd41b55f3e3.png
